Wifi condition = state not connected
HI all
I am trying to add a simple automation but it is not working.
the trigger works but the condition isn’t. I tried
not connected
<not connected>
<not_connected>
What is going wrong?
  alias: trigger when connected to wifi
    - platform: state
      entity_id: sensor.makis_smartphone_wifi_connection
      to: "mkDevices"
    - platform: state
      to: "COSMOTE-CBA6C4"
  condition:
    - condition: state
      state: "<not connected>"
      for: "00:05:00"
    - service: switch.toggle
        entity_id: switch.sonoff_100082f960
  mode: single```
<not connected> that’s the one it should be. However you are triggering on it being connected, so the condition will never be true.
Trigger occurs first then conditions are checked.
you are right :slight_smile:
probably I need a sensor/helper for the condition?
or could I change the condition to trigger and vise versa?
I prefer not to use extra sensors if not absolutely necessary.
You haven’t said what you want the automation to do.
I need to toggle the switch the moment my phone connects to my wifi network. without the condition although it triggers more often than i need.
the minutes will be more the 20 in the end. I have it on 5 to test it only
If you only want the automation to trigger every 20 minutes at most try this:
    - platform: state
      to: "mkDevices"
    - platform: state
  condition:
    - condition: template
      value_template: "{{ now() - this.attributes.last_triggered|default(as_datetime(0),1) > timedelta(minutes=20) }}"
  mode: single
yes, it worked!
Thank you Tom
