I am using an AIMesh system, so I have various routers with the same SSID but of course each router has a different MAC.
Is it possible to tell to connect to that specific router instead of choosing it random?
You might be able to do something with the roaming list in the router.
Roaming list?
Is that a function of the router? By any chance you know if Asus router have it?
Yes it is a function of the router. No, I use Ubiquity gear. Try the SNB Forums.
A quick search shows there is a Roaming BlockList, that blocks clients from roaming but they may still connect to a weak node. What you need to search for is “Roaming assistance” to ensure your clients always connect to the strongest node.
