Hi all, I have an older Polar Sauna HMR 60 heater with built-in mechanical dials for temperature control and timer/shot off. It takes over an hour to heat the sauna to the right temperature. So after 20 years, I finally decided to automate turning the heater on and off.
I’m looking for advice on hardware configuration to set up WiFi control and how to integrate it with the current circuit. The temperature dial stays on maximum all the time. I have a 220V line on a 50A breaker going to the sauna.
Thank you for the heads up.
