WiFi In-Wall Outlets for Home Assistant
Hello. I know there are many integrations so there probably are tons of options. I am looking for a wifi smart in-wall outlet that has control over both receptacles separately. I need this to integrate to HA through some means that does not cost $.
Thank you.
Get a Shelly 2PM and wire it to the back of a regular outlet.
Assuming this is in North America, be sure to remove the tab between the two brass screws so that you can control each outlet independently. If uncomfortable with this, an electrician will know exactly what to do!
Did not think of that. Thank you for the idea.
