Wifi_info text sensor does not show ip address
Since I upgraded my nodes to 1.14.3 my text_sensor: platform: wifi_info (ip address and ssid) show unavailable. WiFi signal works and node is connected to Internet. Any ideas? The nodes on version 1.13 show the information correctly.
Hi @laca75tn
I’m running into this now as well - any insights?
No problem here. What is the relevant yaml?
Double check your entity registry in HA to make sure they didn’t get recreated with _2 Appended to them. I had that happen once after an ESPHome firmware update or HA update, can’t remember which. It’s not an ESPHome issue necessarily, could have been caused by HA.
Yes, that was my issue. Check the registry
