Wifi interface missing on intel NUC
Hi all,
I was reading the forum for days but I could not find a solution for my issue:
I have installed HA OS on an intel NUC with SSD.
All my wifi devices leave in a dedicated VLAN with specific network access (including my Google assistant and HomeKit devices)
After installing the latest version I have 2 issues:
  1. I cannot find the wifi interface
  2. nmcli command is not present in the OS
I tried adding one USB wifi dongle. i can see it in dmesg logs but the interface cannot be enabled.
Any guidance or advice will be highly appreciated.
Thank you
Why would you want WiFi on the NUC?
The reason you haven’t seen anything on the forums should be a hint- it’s a bad idea.
I get this, but I need to connect my NUC to the wifi, otherwise, I cannot add the bridge to homekit via my phone.
being in 2 different networks I cannot make the bridge with HomeKit
what ?, are your phone and “Bridge” on another network ?
PS: I could’t help notice you have 20min Read time here, have you tried to read about connecting wifi to “Intel”-NUC ? … and make that work first ?
yes. My phone is in the wifi Vlan network and my HA is in the Lan VLAN network now
I could not find anything NUC wifi related
Intel have some “info” in regards to Wifi on Intel-NUC
Interresting
What does this mean? A drawing of your net connections would help. Do you have two separate networks? If yes, then it isn’t going to work.
I know that you can have the WiFi in a Nuc on a different network than the ethernet, it’s Linux, after all. But HAOS is not the Linux we all love. I am just guessing, but having multiple network interfaces is probably something that would have to be integrated into the core.
Why do you need different networks?
unfortunately i need 2 different networks.
Possibily a case for a general-purpose base OS?
fair. I will probably do a reinstall some time soon.
for now it works just fine as is, but with this limitations of not being able to integrate homeKit
which Bridge are you actually talking about ?, i guess it’s the bridge your devices are paired with, is this a wifi-only bridge/ or a usb-bridge ? … i mean adding a (some)Bridge to the integration Homekit, that’s what you want to achieve right ?
Edit: excuse me if it sounds like a stupid question, but i have never had to have my HA on WiFi, in fact i don’t have wifi_interface in my HA , as i disabled the wifi during VMware-installation, and never had the choice to “Bridge” the WiFi interface, so i only have Ethernet and Bluetooth, the only time i need my phone, is when i paired devices to the “Controller/Hub” maybe that’s what you call Bridge
My mom would smack me when my answer was “because!”.
I separated Wifi users from Lan and Wifi guests via 3 different VLANs
every ssid is associated to a VLAN id same for LAN endpoints
can be closed. I included the Lan clients in the same VLAN as the wifi ones.
