Anyone else having problems with esphome on Wemos D1 mini V 4.0.0 (with USB-C connector) and connection to Wifi taking 5-10 minutes to connect and showing “auth expired” messages in the logs. They eventually connect without a reboot or re-flash.
Bought a first batch of these V 4.0.0 devices because the previous V 3.1.0 are no longer available. We have 20+ V 3.1.0 devices connected and they all work without any issues and in the same location.
Hi, did you find any solution or explanation to your problems with D1 mini v4.0? I have the same problem, I bought a number of these Wemos D1 mini 4.0 with USB-C connector. They don’t connect to wifi every time they are re-fashed or rebooted.
/Magnus
What WiFi switch and firmware are you running? OpenWRT by any chance?
Does the WiFi signal appear to be weak?, or does it not see any WiFi if you monitor the ESP on bootup using serial?
No, I started using static IPs and the problem went away.
Using multiple 3.0 D1s that are working with my UniFi network (6 APs around the farm) on DHCP. For some reason only the 4.0 devices have problems.
I worked with the Swedish distributor with my case (m.nu). Side-by-side on the desk, the 4.0 device never connected with 100% success while using DHCP but the 3.1.0 did every time.
m.nu is where my d1 mini v4.0.0 cards where bought. Static IP did solve my problems. But they are not as stable as my other esp8266 cards.
The Wifi signal is not weak and I’m not using OpenWRT. But maybe there are some router settings messing with my connection. I’m on an asus ax router.
I second that comment about stability - they are horrible. I have stopped the using the “D1 mini” version 4.0.0 for the “D1 mini Pro” from m.nu.
I tried a bunch of D1 Mini v4’s from an Aliexpress seller. Similar Wi-fi issues with ESPHome and Tasmota. Mostly as temperature sensors but also with IR senders. My router is an Asus with Merlin firmware (DHCP) but that shouldn’t matter. Constant dropouts, sometimes for hours. I tried various power supplies too. Had better luck with higher-rated Blitzwolf USB plugs but still took a few minutes to come online and would drop out randomly, sometimes coming back online, but very often not.
I can’t even guess what the problem would be, so I’m back to D1 v3s which are now available with USB C plugs.
If the issue can be fixed by using Static IPs, that seems like a problem with the internal logic of the Wi-fi and can’t be fixed by any firmware. Pity. Relying on fixed IP is not a great solution but at least it’s good to know so MAYBE I can salvage them.
We have stopped using the D1 Mini and instead using the D1 Mini Pro version instead.
I have recently experienced wifi/esphome/D1mini HELL for over two weeks. The issue was resolved by rolling back the router/accesspoint firmware on my Asus RT-AX88u hardware from version 388 to the previous version 386. Something in the Asus/Broadcom platform changed, and for the worst. TP-Link wifi devices, Ecobee thermostats, and Amcrest cameras were all affected. It’s definitely the Asus/Broadcom 388 firmware.
I was likely on 386 or older when the issues with the D1 v4’s happened. I’ve been on Asus RT-56U with version Merlin firmware 388.2. Before blaming the firmware, look at the checklist here: Best setup for the Asus RT-AC68U (ACTUALIZED to 2019) | SNBForums
It feels like not using your router’s full potential, but after following this checklist, I’ve had a rock-solid network with more than 50 Wi-fi devices. The router reboots once a week just’ cause but I let it go for 3-4 weeks uptime without issues.
Just today, I began to notice something peculiar. On my Asus router (stock Asus 386 firmware) several of my Wemos D1 Mini ESP8266 devices were appearing with Espressif
rather than their assigned DNS node names. This plays havoc with mDNS connectivity and status. ESP32 devices did not appear to have this issue, only ESP8266 devices. Recompiled and reloaded ESPHome firmware OTA where possible, and using ESPHome Loader where necessary. Things appear to be 100% online and stable at the current time.
Current ESPHome version 2023.4.4
Hi – Has anybody found a more permanent solution to this issue? I bought 10 Wemos D1 Minis with none being able to connect to the WiFi network, despite the static IP. I also deactivated Captive Portal with very little luck. Any thoughts? Thanks!
Did you ever get your issue resolved?
No, not for me. Trying my 4.0 devices with each release of ESPhome or Unifi AP firmware but no luck so far.
I’m seeing the same thing with Google nest wifi, also with 3.0 devices…
What board type are you selecting for them in your config? Is it not connecting to HA and is with the router or wont connect at all? Do other types of esp boards ha e the same problem or do they work fine?
Why are none of you all posting configs, logs, etc and maybe see what things you have that are in common? If you all have X, Y, and Z in common, thats what they call a “clue” Those are good places to start finding solution or tell you things you can confidently say isnt likely to be the problem.
Did anyone go look at the documentation and see if there was a past breaking change for those boards?
Anyone do a forum search on here? The odds that you few people are the only ones ever to have this problem, those odds are in your favor…
Anyone try Google or Reddit?
If you try something and fail to find anything or it failed to fix the problem, that isnt worthless information unworthy of posting! That information is gold!
Its another box to check on your “troubleshooting process of elimination” It also saves us from wasting our time on things that have been tried already. Most importantly it shows that a person is at least trying and making an effort other than posting “me too” so the thread gets bumped to the top.
Valid point!
Here’s the config for me:
esphome:
friendly_name: wiegand-keypad-wemos
platform: esp8266
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "pvVSC1bk9beN7TzRxE6VeIgLmMHjjd1xxbdqMW1LtGA="
ota:
- platform: esphome
password: "fdeda14edd4fe96f2df19d20262ac45b"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Wiegand-Keypad-Wemos"
password: "BWJtNfPskF05"
captive_portal:
And here’s the log:
[I][logger:034]: Log initialized
[16:43:07][C][safe_mode:079]: There have been 0 suspected unsuccessful boot attempts
[16:43:07][I][app:029]: Running through setup()...
[16:43:07][C][wifi:047]: Setting up WiFi...
[16:43:07][C][wifi:060]: Starting WiFi...
[16:43:07][C][wifi:061]: Local MAC: 84:F3:EB:B4:B7:DD
[16:43:07][D][wifi:481]: Starting scan...
[16:43:07][W][component:157]: Component wifi set Warning flag: scanning for networks
[16:43:13][D][wifi:496]: Found networks:
[16:43:13][D][wifi:544]: - ''[redacted] (B2:8B:A9:91:44:68) [redacted]▂▄▆█
[16:43:13][D][wifi:544]: - ''[redacted] (FA:92:BF:C4:F4:E7) [redacted]▂▄▆█
[16:43:13][D][wifi:544]: - ''[redacted] (7E:45:58:7A:BE:58) [redacted]▂▄▆█
[16:43:13][D][wifi:544]: - 'netis_509254'[redacted] (00:72:63:50:92:54) [redacted]▂▄▆█
[16:43:13][W][wifi:550]: No matching network found!
[16:42:57][W][wifi_esp8266:501]: Event: Disconnected ssid='UniFi88' reason='Probe Request Unsuccessful'
[16:42:57][W][wifi:652]: Error while connecting to network.
[16:42:57][I][wifi:312]: WiFi Connecting to ''...
[16:42:57][W][wifi:673]: WiFi Unknown connection status 0
[16:43:02][I][wifi:312]: WiFi Connecting to 'UniFi88'...
BTW, my WiFi networks are broadcast at both 2.4GHz an 5GHz. When I specifically chose the 2.4GHz one (through the bssid
option, it didn’t resolve the issue). Happy to provide more information as all my Wemos 4.0 are unusable.
Many thanks!
