WiFi laptop cannot reach Ethernet Home Assistant OS laptop
Hello! I just installed HAOS on an old laptop of mine.
Everything was fine. I went into the web browser, logged in, configured a static IP all via ethernet cables. Now the HAOS is running on LAN via ethernet and my laptop is on WiFi. I can no longer access HA, nor via my phone.
I checked the IPs from my PC and HA and they are on the same subnet. Pings don’t work, the static IP of HA is unreachable. If I plug the ethernet back in my laptop it works once again. I went into the router setting and the WLAN should be able to communicate to the LAN.
I can see both HA and my laptop on the router table of connections. But they cannot reach each other unless I plug ethernet cable in my laptop.
Please help…
