I have a wifi LED status indicator,
When connected, the LED displays GREEN at 100% which is correct.
On disconnect, the LED flashed red at 100% brightness, which again, is correct.
However, when the ESP reconnects to the network, the LED does not return to the GREEN state but rather continues to flash RED in the error state.
Any idea why this could be hapenning?
wifi:
networks:
- ssid: !secret wifi_ssid
bssid: xx:xx:xx:xx:xx:xx
fast_connect: true
on_connect:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
on_disconnect:
- light.control:
state: on
effect: ERROR
####Status LED Start####
light:
- platform: fastled_clockless
pin: 23
chipset: WS2812
num_leds: 1
rgb_order: GRB
restore_mode: ALWAYS_OFF
effects:
- lambda:
update_interval: 0.2s
lambda: |-
static bool state = false;
auto call = id(led).turn_on();
call.set_transition_length(500);
call.set_rgb(1, 0, 0);
if (!state) {
call.set_brightness(1);
} else {
// If using 0, it freaks Home Assistant UI.
call.set_brightness(0.01);
call.perform();
state = !state;
- lambda:
lambda: |-
call.set_rgb(0, 1, 0);
if (!state) {
} else {
call.perform();
state = !state;
####Status LED END####
