Wifi LED strip controller?
My wife bought some LED Strips that we use to accent the living room and underneath kitchen cabinets.
Problem is, the ones she bought have a bluetooth controller that I presume isn’t compatible with HomeAssistant.
These are 4 prong connecting LED Strips. Are there any LED Controllers that work with HomeAssistant so I can get these strips to work with HA?
If they are addressable LEDs you wont find better than WLED.
It does do RGB lLEDs - with some extra hardware.
How interested in DIY are you? :wink: If you are (and you should be :smiley: ), ESPHome is the perfect solution for you. You connect the LED strip to your ESP8266 or ESP32 and can flash it with your own firmware (ESPHome).
AS much as I love ESPHome, for a LED controller WLED is better.
I found this:
https://www.hadevices.com/product/124
Pretty handy website, actually. Has a lot of recommendations for various devices that work with HA.
Totally agree, but if someone wants to start into the “ESPbased universe”, I find it less scary with ESPHome. :slight_smile: It integrates better with HA and the installation and flashing procedures are easier, at least if you run HomeAssistantOS or supervised. :slight_smile:
And, when not so common with DIY, here an another idea.
I use this in my hosue a lot.
https://www.futlight.com/light/xqy/ls2.html
How does it integrate into HA? is there an integration or it is a YAML configuration
It works with the LimitlessLED integration.
