Winter is coming so… any news on the API availability or hack possibility?
I’ve been using the Aeotec zwave TRVs but they are hard to find to this year and I am not very happy with them anyway.
I decided not to go for the Comet Wifi but bought a set of Eurotronic Spirit Zigbee instead, which integrate into HA quite nicely. https://eurotronic.org/produkte/zigbee-heizkoerperthermostat/spirit-zigbee.
As I said, it is (was) possible to control the Comet Wifi valves, that was actually very easy. The only problem is that it was to easy. It was possible to control EVERY Comet Wifi device (from any user) by simply connecting to a cloud mqtt server without any authentication.
I did see just yesterday, there is a new app for the Comet Wifi in the app store now. The old app now shows a notification that you can do a software upgrade so you can
Benefit from our new security concept for more security in your home.
I have not tested the firmware update or the new app, because I basically gave up on these and already have the ZigBee devices now. My guess is that after you do the firmware updates of the Comet Wifi it is no longer possible to control it via mqtt, but only via their new (secured) cloud service. This removes both the security issue and the possibility to control them from HA.
That’s the current reply, received just now:
Sehr geehrter Herr Herzog,
nein leider kann ich Ihnen noch keine erfreulichen Neuigkeiten bzgl. Der API mitteilen.
Dies benötigt leider noch etwas Zeit.
That was my mail:
Guten Morgen Frau Jung,
nachdem der Herbst mittlerweile Einzug erhalten hat und die Temperaturen nur noch knapp über der Null-Grad-Grenze liegen, möchte ich hiermit anfragen, wie der Stand der Dinge bei der Thematik API ist? Ihre letzte Information hierzu lautete Ende August 2021 - wann kann mit der API gerechnet werden, um die Geräte in die eigenen Systeme einbinden zu können?
So basically: There’s no news about this, the development of the API needs more time…
I reverse engineered their internal api. If you want to, I can give you the insides you need to run your code. Feel free to contact me.
Hi everybody,
Thanks for sharing the feedback from Eurotronic! Very useful information.
This product is exactly what I was looking for, however the user reviews on Amazon are VERY bad. Based on those reviews, I am not sure at the moment if only their app is not good, or also the hardware. Because I also see some complaints about the batteries, accuracy of the temperature readings, … Therefore I would appreciate a lot if some of you could share some experiences about these devices, before I buy them.
@DrFuehrer: kind of impressive that you managed to reverse engineer the API. Would really like to hear what you have found, because I had not planned to use their app. Do I need to send you a private message, or is it appropriate to share your results here?
Thanks!!!
Bart
Not strictly on topic but I think the quest for exploring this thermostat was ended by Shelly TRV.
The sales will start from 4th of April 2022 and currently there are no independent hardware reviews but considering what Shelly has been known for this should be the ideal TRV. No need for hacking and reverse engineering the API as everything is open by default.
Agree. If you wait long enough to listen to customer requests and don’t take their privacy seriously, competition will catch up.
I did found a Comet wifi on Amazon and bought it, just installed actually… I did read (probably wrongly) that it should be possible to use them with Fritzbox… yeah when you have the DETC version… I fill honesty that either Hama and Eurotronic both sucks a little… the TVR can be setup in them own app that don´t even complete the setup of the device because of a “required wifi radio software update”. Fritzobox don´t detect them as TVR… as I wished in the begin as per there is a Fritzbox integration that should allow to expose the device to HA… nice it works with wifi… but out of the box… where is the api that wold allow us to integrate them?
Hello everybody
I am using those fellows since a year. And I am quite happy with it.
Only “quite” because of some issues.
Does anybody can update the things? I can’t update any of them. And don’t see the name of the last one in the list for update. This is quite disturbing.
Hi all,
I’ve gotten basic functionality working with custom DNS entries, redirecting MQTT messages to Home Assistant.
I’ve written a guide with configuration examples here if you want to check it out.
Hi ivando,
Could you share some data about the battery autonomy of your TRVs ?
Hallo,
ich hätte Interesse an der API für die COMET WIFI Thermostate.
Grüße Uwe
I have successfully integrated the Comet WiFi into Home Assistant. I wrote a blog post about it:
