Integrating Comet Wifi basic functionality
Comet Wifi
The Comet Wifi [^1] is a german built decently cheap Wifi (2,4GHz) smart thermostat. They don't need a gateway and come with their own app. I got these gifted to me so I had to adapt them to HA, but that is only a solution for power users, as it cost me quite a bit of effort to get them running.
Introduction
The Comet Wifi thermostats are fine as standalone devices, altough the app seems pretty terrible.
I wanted to integrate the thermostats in Home Assistant to collect temperature metrics (they include thermometers) and set up central automations.
Setup
You will still need the app for updating the devices and onboarding them to the correct SSID. A couple of things to look out for:
  • You need to temporarily connect to the SSID of the thermostat - make sure you disable the automatic disconnect for the SSID since you won't reach the internet. My Pixel 6 kept disconnecting from the SSID during setup which makes it impossible to complete. They now also warn about this behaviour in the app now.
  • You need to complete the setup. After pairing with the comet's SSID the next step will tell you that the setup is complete. Do not close the app, you actually need to press OK/NEXT two more times.
How it works
Many thanks to [^2] for bringing me on the right track on how to go about doing this. There also was a thread on the HA forums discussing this [^3] with the possibility of the API specs being published, although that hasn't seen updates since october 2021. In short I'm spoofing the DNS entries for the Eurotronic public broker to my own HA server. On this server I run automations and sensors to interact with the thermostats.
Limitations
So far I can set the target temperature and read out the current temperature. This may seem like not a lot but it's about the capability the Eurotronic app has as well. The app also lets you create and apply heating profiles - setting different target temperatures at different times - holiday profiles, open window detection and of course firmware updates. My devices are running on:
Base-Software: 5.0
Radio-Software: 2.4.2.4
The app also allows reading of a few other metrics (battery level, wifi strength, connection status) which I haven't gotten around to implementing yet / I don't know if they are even accessible over MQTT or only via the fabled API.
The profiles we can recreate in Home Assistant pretty easily with automations, for everything else you will need the app.
Most things in the app are set and forget though, the thermostat will (in theory) do everything else by itself.
How to make it work
MQTT
If you don't care about MQTT or already know how it works skip this part.
Disclamer - I have no idea what I'm talking about but this is my understanding of MQTT right now and how I made it work.
MQTT is an IoT protocol that works over TCP. It uses a centralized Broker to publish messages to Clients using the Topic as a way to determine the corresponding devices.
Here's how this usually works:
  • A client starts a TCP connection to the broker
  • the client sends an MQTT connect message for authentication
  • the client sends MQTT subscribe messages specifying the topic they want to be informed about
  • once the broker receives a message for that topic it will forward the topic/message combination to the client
  • a client can send a message to whatever topic and the broker will forward this to all subscribed clients
This doesn't usually need any firewall rules, since the clients are starting the TCP connection to the broker (in Eurotronic's case a public one) - the connection just gets left open for as long as possible for the broker to inform the client about messages on topics.
The thermostats send unencrypted MQTT messages to either mqtt.eurotronic.io or mqtt1.eurotronic.io.
What you need
You will need:
  • a HA server with a MQTT broker Add-On (I'm using mosquitto)
  • a DNS server that is set by DHCP (I'm using Unbound on OPNSense)
  • probably a bit of patience
Making it work
DNS
Set up a DNS override in your DNS Server pointing to your HA server for the A-Records
mqtt.eurotronic.io
mqtt1.eurotronic.io
In case the devices are in a different network than your HA instance you also need a firewall rule from the devices to HA server on TCP port: 1883.
MQTT
Broker
Install the Mosquitto broker Add-On for Home Assistant and follow the instructions on the documentation page to get it running.
Credentials
Luckily all thermostats use the same username/password combination for the MQTT connection. Add the following to the "Logins" section of your Mosquitto configuration:
- username: 00002F71
  password: 50D6D8B5DA33799A
This worked for me. If your thermostats have different credentials you will see them denied in the mosquitto logs. The way to get the credentials is to packet capture the mqtt connect message - you can trigger an mqtt connect by removing the battery on a device and then putting it back in.
Topics
The thermostats will subscribe to several topics, topics are always constructed like this:
02/00002F71/[Device-MAC]/[Ending]
There are 4 endings that are interesting to us:
  • /S/XX
    • this is the topic the thermostat will use to verify connection to the broker, not necessary but I believe connectivity will be more stable if this is used
  • /S/AF
    • this is the topic where you can request the current target and actual temperature, send the message #0B
  • /V/A0
    • this is the topic the thermostat publishes it's current target temperature to
  • /V/A1
    • this is the topic the thermostat publishes it's current actual temperature to
Wildcards
MQTT topics support wildcards, there are two wildcards you can use, # and +:
  • # can only be used at the end of a topic and is a general wildcard for all subtopics that will follow
    • Example: 02/00002F71/# - this will match everyting every thermostat publishes
  • + can only be used in the middle of a topic and is a wildcard for all
    • Example: 02/00002F71/+/V/A0 - this will match for every thermostat but only on the ending for the current target temperature
Home Assistant
At first I tried to set up automations that "translated" the topics into more manageable ones that would make automation easier. As this was my first project with HA I spent about 15 hours getting familiar with yaml and jinja only to scrap all the automations and redo it but oh well.
My current approach utilizes mqtt sensors for the actual temperature and input numbers for the target temperature. Then I have automations set up with mqtt topics as triggers which will in turn execute scripts that interact with the input number and the other way around allowing for bidirectional configuration since after every change on the device, it will also send out the new target temperature.
I will include the configuration samples for one thermostat here.
Value conversion
It would be too easy to just send and receive the values we want as they are so we will need to do a little conversion for incoming and outgoing values.
I will leave them here for easy access and also include them with the configuration examples below.
The thermostat will send a message like #2C which will correspond to the temperature of 22°C.
To get to that value we need to perform a couple of steps:
  • strip the leading #
  • convert to decimal
  • divide by two
These are the conversion templates I came up with:
  • Incoming
    • {{ int(value[1:],base=16)/20 }}
  • Outgoing:
    • {{ "#" + "%0x" %int(float(temp)*2) }}
Looking at this now I'm pretty sure the integer conversion on the outgoing values isn't needed but oh well.
Configuration
In the configuration we will need the two components discussed above:
mqtt:
		- name: kitchen-temp
			state_topic: 02/00002F71/[Device-MAC]/V/A1
			unit_of_measurement: °C
input_number:
	temp_kitchen:
		initial: 20
		min: 13
		max: 30
		step: 0.5
Automations
To set up a basic dashboard you will need a minimum of 3 automations:
  • Receiving target temperatures
  • Setting temperatures
  • answering #COMM-TEST
- id: ''
	alias: Receive Target Temperature
	description: ''
	  - platform: mqtt
	    topic: 02/00002F71/+/V/A0
	condition: []
		service: script.update_target_temparature
			topic: '{{ trigger.topic }}'
			payload: '{{ trigger.payload}}'
	mode: parallel
	max: 50
- id: ''
	alias: Set Target Temperature
	description: ''
	  - platform: state
	    entity_id:
		    #include all your input numbers here
		    - input_number.temp_kitchen
	condition: []
		service: script.set_temps
			temp: '{{ trigger.to_state.state }}'
			target: '{{ trigger.entity_id }}'
	mode: parallel
	max: 50
- id: ''
	alias: 'Answer #COMM-TEST'
	description: ''
	  - platform: mqtt
	    topic: 02/00002F71/+/S/XX
	condition: []
		service: script.answer_test
	#since request and answer are on the same topic set mode to single and add optional delay otherwise this will run in a loop and drain the battery of your thermostat
	- delay:
		minutes: 1
	mode: single
Scripts
You will also need a minimum of three scripts to pair with these automations
update_target_temparature:
	alias: "Update Target Temperature Input Number"
	fields:
		topic:
		payload:
	sequence:
		- choose:
			#choose for the different thermostats, depending on the MAC in the topic
			#repeat this conditions block for every thermostat, replace the device MAC and the input number
			- conditions:
				- condition: template
				  value_template: '{{ topic[12:24] == "[Device MAC]" }}'
			  sequence:
			    - service: input_number.set_value
					    entity_id: input_number.temp_kitchen
					    value: '{{ int(payload[1:],base=16)/2 }}'
	mode: parallel
	max: 50
set_temps:
	alias: Set Temperature
	fields:
		temp:
	sequence:
		- choose:
			- conditions:
				  value_template: '{{ target == "input_number.temp_kitchen" }}'
			  sequence:
			    - service: mqtt.publish
				      topic: 02/00002F71/[device MAC]/S/A0
				      payload: '{{ "#" + "%0x" %int(float(temp)*2) }}'
				      qos: 2
    mode: parallel
    max: 50
answer_test:
	alias: Answer COMM-TEST
	fields:
		topic:
		payload:
	sequence:
		- choose:
			- conditions:
				  sequence:
					- service:
						  topic: 02/00002F71/[device MAC]/S/XX
						  payload: "#COMM-TEST"
						  qos: 2
Conclusion
With these tools you should have everything you need to never touch the Eurotronic app ever again... surely.
Right now I'm still having some connectivity problems with one thermostat, which keeps reverting to the eurotronics server based on either a DNS cache or a hardcoded IP-Address. This can be fixed by either restarting the device by briefly removing power, or disconnecting them from the SSID manually (I do this on my Aruba IAPs). I might automate this too, so if my firewall can see the thermostat connecting to the public server it will trigger a disconnect by the IAPs but that's a task for another time.
[^1] Comet WiFi - EUROTRONIC Technology GmbH : EUROTRONIC Technology GmbH
[^2] https://techoverflow.net/2021/12/27/packet-capture-mit-wireshark-des-eurotronic-comet-wifi-heizkoerperthermostats/?lang=de
[^3] Wifi radiator valve thermostat - Eurotronic Comet Wifi
Great work! I also did some wiresharking when I was playing with this device. I was looking for the DNS request to be able to do something similar but was not able to find it. I did make notes of the command I found. Especially the S/AF is usefull, when you send it to the device it will respond with a series of messages reporting all kind of internal information
V/ set value
S/ reportvalue
A0 setpoint
A1 current temp
A2 temp Offset
A3 options bitfield keylock / sumertime / rotate display
	#200700 rotate off
	#220500 rotate on
	#230400 activate summertime
	#220500 deactivate summertime
	#270000 key lock on
	#230400 key lock off
A5 => window open settings #1234
	last byte = duration in min
	first byte senitivity
	X80 => high
	X08 => middel
	X0C =>low
A7 - holiday settings
A8 - AE weekday program
S/AF = #02000000 -- connect with app, request current temp
             #FFFFFFFF - request device to send all fields back
Amazing work! Glad you got it to work!
Super interesting to learn there is an MQTT connection you were able to piggyback on! I take it their MQTT broker does not allow subscriptions for the credentials the thermostats use?
Now I need to order one of these devices to test as well :smiley:
Are you saying the current temperature is published in full degrees resolution? Would be great if you could summarize which actionable data points you were able to see. How about the valve state (0-100%) for example? @FrankBakkerNl is your list complete?
The temperature has a resolution of 1/2 degree. If I recall correctly it is encoded by multiplying the value by 2 and translating to hex in ASCII. The same encoding is uses for setting and reporting temperature valies
I got these commands by monitoring the mqtt messages with an mqtt client while using the app and some experimenting.
When I tried this they had an unsecured Mqtt server in the cloud. I could just connect to that server and see all messages (incl.) Those of other users
I shouldn’t have asked :see_no_evil: wtf
Thanks!
I think the best way to get it to work as a climate in HA is by using this
It can be configured to map target and current temperature from other entities which can then be synced via mqqt
Great finds, those are a lot more than I thought there to be. I only really wiresharked for the temperature values.
I don’t think generic thermostat will really work, unless there’s a trick I don’t know of yet.
It uses a sensor and a switch connected to a heater or air conditioning under the hood.
and it requires a toggle device as a heater, where as we would ideally want an input number:
heater string Required
entity_id for heater switch, must be a toggle device. Becomes air conditioning switch when ac_mode is set to true.
Seems to me this would only turn a device on or off, but that’s a job the thermostats are already doing themselves.
From what I’ve seen there’s a whole new integration needed. I’ve looked into writing integrations a little bit but I’m not sure I could do it yet. I will do more research into what kind of effort that would take.
Not sure about that one, I’ve seen in the mosquitto logs that the phone app also authenticates with the same username, although the log entry looked a little different. But if you can reverse engineer the way the phone app works, you could also have HA act as the client probably. Everything is in unencrypted MQTT 3.1 so easy to packet capture.
Great work!
I just integrated three of them and I can set and receive the desired temperature (after some adaptions to the scripts above). I’m still working on how to get the actual temperature (periodically?).
I also think, it’s a kind of new device, where you just “program” a thermostat (but I don’t know if this already exists). I have two different scenarios in my mind:
  1. Just program the thermostat like the APP does and let it run.
  2. Disable almost all functions on the thermostat and control it via HA.
Since I’m a newbee here I don’t know how to write code for a new device (1). Is there any template I can use to modify/adapt?
The second approach seems to be more easy (for me).
Can somebody give me some hints?
you can get the temperature periodically by setting up an automation that sends “#0B” to the /S/AF topic of each thermostat, like so:
  alias: receive current temps schedule
  description: ''
  - platform: time_pattern
    hours: /1
    seconds: '30'
  condition: []
        topic: 02/00002F71/D43D391523AA/S/AF
        payload: "#0B"
        qos: 2
  mode: single
  trace:
    stored_traces: 10
This will run every hour and thirty seconds (10:00:30, 11:00:30, …).
The thermostat will then send out info to the /V/ topics which should update your MQTT sensor listening to /V/A1
Keep in mind that doing this will drain their batteries faster.
I’m going with option two. While in your local network you can also use the app to program the thermostats since your phone also talks to the HA MQTT broker, since I only implemented temperature control so far.
Also now that I’ve gotten more familiar with Home Assistant I would no longer use scripts the way I do currently. You can mirror everything in the script directly in the automation action, so you should probably only be using scripts when you need to reuse them often. I’m currently thinking of two ways to do this that make it feel “more correct”:
  1. Make a few big automation that run regularly and have the logic in the automation action using conditions
  2. Make many small automations that each have minimal logic in their automation conditions.
Right now I have most of my previous setup migrated to big automations but I’m not spending a lot of time on this right now so progress is slow.
Hello all,
thanks for you great work, it was a good starting point for me. I have 9 Comet Wifi running since October 2022 and a Homeassistant running since 4 weeks on my Rock4SE board. I’ve not setup PiHole, yet, so I’m using nextdns.io as intermediate solution to change the eurotronic addresses. I’m still at the point reading data from the devices, so I’m still using the app as controller (it still works with the local Mosquitto) and the internal temp profile schedulers (just kept it as it was).
But I’m facing some issues, maybe you have some ideas:
  • FYI, my devices have different username/password combination, so it seems not to be a fixed value for all devices. But all have the same, so I guess it depends on app setup
  • One device lost time sync, it gets like all other time via time.windows.com at boot, but scheduled temp profiles are triggered at wrong time, maybe on the device the timezone setting got garbled, maybe using …/S/AF with #FFFFFFFF payload? I found maybe a solution for this. In wireshark I found a topic sending a timestamp like this: 02/FFFFFFFF/000000000004/T/B7: #23.03.09-09:00 (UTC). Further investigating by subscribing to mqtt.eurotronic.io I found that there are 4 of these topics (considering daylight savings time or not), so I added this to my 10-minute automation:
alias: Comet Scheduler
description: ""
    minutes: /10
condition: []
      qos: "2"
      topic: 02/FFFFFFFF/000000000001/T/B7
      retain: false
      payload_template: "{{ now().strftime('#%y.%m.%d-%H:%M') }}"
    alias: Timestamp 1
      qos: "2"
      topic: 02/FFFFFFFF/000000000002/T/B7
      retain: false
      payload_template: "{{ (utcnow()+timedelta(hours = 1)).strftime('#%y.%m.%d-%H:%M') }}"
    alias: Timestamp 2
      qos: "2"
      topic: 02/FFFFFFFF/000000000003/T/B7
      retain: false
      payload_template: "{{ (now()-timedelta(hours=13)).strftime('#%y.%m.%d-%H:%M') }}"
    alias: Timestamp 3
      qos: "2"
      topic: 02/FFFFFFFF/000000000004/T/B7
      retain: false
      payload_template: "{{ (utcnow()-timedelta(hours=12)).strftime('#%y.%m.%d-%H:%M') }}"
    alias: Timestamp 4
  • Another device lost connection to the local Mosquitto overnight, wiresharking a hard reboot shows that it still gets the local router DNS server but didn’t ask for mqttx.eurotronic.io. Instead it directly contacted IP address of mqtt1.eurotronic.io. Do you know if IP addresses are persistently cached on the devices? Or is the device now in a fall-back mode using hardcoded address? I solved this by removing local DNS rewrite and then reboot the devices again. Then re-enabled the DNS rewrite and cycled wifi connection. All is still a little bit tricky and not stable.
    Some weeks later I still have problems with sporadic disconnection of devices from MQTT (#COMM-LOSS) which requires reconnection of WiFi. Keep observing.
I didn’t do any factory reset on the devices, yet (I guess this would require to restore original eurotronic connection so the devices could be setup with the app).
I’m not yet very experienced with Homeassistant scripting. Current approach to manually add all devices to config.yaml looks not very generic. Is it somehow possible to create the entities with a loop over the MAC addresses automatically (I didn’t figured it out, yet)?
Hello everyone,
can someone adjust thermostat definition from linked forum to our Comet WiFi? Is that even possible? It would be nice to use the thermostats as such objects.
Hello @hausmeisterHA,
I’m experimenting with a climate configuration that seems to work.
Paste this to your developer-tools/template section and replace name: topic in the map at the beginning with yours:
{% set comet_map={
  "Wohnzimmer": "02/0000XXXX/YYYYYYYYYYYY",
  "Schlafzimmer": "02/0000XXXX/YYYYYYYYYYYY",
mqtt:
    {% for name,topic in comet_map.items() -%}
    {% set mac=topic[-12:] -%}
    {% set id=name|lower|replace("ü","ue") -%}
    - name: Heizung {{ name }} Battery
      object_id: comet_{{ id }}_battery
      unique_id: sensor.comet_{{ id }}_battery
      device:
        identifiers: [ '{{ topic }}' ]
      state_class: measurement
      device_class: battery
      unit_of_measurement: "%"
      state_topic: {{ topic }}/V/A6
      value_template: "{{"{{"}} int(value[1:],base=16) {{"}}"}}"
    {% endfor %}
  climate:
      unique_id: climate.comet_{{ id }}
      device:
        connections: [ ['mac', '{{ mac }}'] ]
        manufacturer: Eurotronic
        model: Comet Wifi
        name: Comet {{ name }} {{ mac }}
      initial: 7.5
      min_temp: 7.5
      max_temp: 28.5
      precision: 0.5
      temp_step: 0.5
      temperature_unit: C
      optimistic: true
      modes:
        - "off"
        - "heat"
        - "auto"
      availability:
        - topic: {{ topic }}/V/XX
          value_template: "{{"{{"}} 'offline' if value=='#COMM-LOSS' else 'online' {{"}}"}}"
        - topic: {{ topic }}/S/XX
          value_template: "{{"{{"}} 'online' {{"}}"}}"
        - topic: {{ topic }}/V/A1
      current_temperature_topic: {{ topic }}/V/A1
      current_temperature_template: "{{"{{"}} int(value[1:],base=16)/2 {{"}}"}}"
      temperature_state_topic: {{ topic }}/V/A0
      temperature_state_template: "{{"{{"}} int(value[1:],base=16)/2 {{"}}"}}"
      temperature_command_topic: {{ topic }}/S/A0
      temperature_command_template: "{{"{{"}} '#' + '%02x' %int(float(value)*2) {{"}}"}}"
      mode_state_topic: {{ topic }}/V/A3
      mode_state_template: "{{"{{"}} 'auto' if value[:2]!='#2' else 'heat' if state_attr('climate.comet_{{ id }}','temperature')>7.5 else 'off' {{"}}"}}"
      mode_command_topic: {{ topic }}/S/A3
      mode_command_template: "{{"{{"}} '#00200000' if value=='auto' else '#20000000' {{"}}"}}"
      qos: 2
      retain: false
    {% endfor -%}
I configured 3 modes: auto is mapped to enabled heat profile in the app, if the heat profile is disabled, this will result to the states off if the target temp is 7.5° or heat if it is higher. I also added a sensor for the battery state and configured devices.
You still need the #COMM-TEST automation from @DracoTomes and an automation to poll the values:
- id: ''
  description: ''
    minutes: /10
  condition: []
      qos: '2'
      topic: 02/0000XXXX/YYYYYYYYYYYY/S/AF
      payload: '#4B'
      retain: true
    alias: Wohnzimmer
      qos: '2'
      payload: '#4B'
      retain: true
    alias: Schlafzimmer
I will work on this to make the automation smart to automatically detect all climate.comet entities, but currently all are added manually. I also added topic to send timestamp here (see my previous post).
Hi there,
I’m kind of “new” to HA (half a year) and have a problem with setting in the code in configuration.yaml:
bad indentation of a mapping entry (98:24)
Maybe someone could give me a hint :slight_smile:
 95 | mqtt:
 96 |     sensor:
 97 |         - name: kitchen-temp
 98 |             state_topic: 02/00002F71/MYDEVICEMAC/V/A1
 99 |             unit_of_measurement: °C
type or paste code here
What am I doing wrong?
Thanks for your help.
I think I got it…
mqtt:
  - sensor:
      state_topic: "02/00002F71/MYDEVIDEMAC/V/A1"
input_number:
    temp_basti_buero:
        initial: 20
        min: 13
        max: 30
        step: 0.5
Hey there,
I’m relatively new to all of home assistant, so maybe I will ask some basic stuff…
I think I got everything set up correctly but my mqtt logs show that my comet tries to log in with a different login. So, I must snoop in on the mqtt connect massage to retrieve username and Password.
I tried to use Wireshark but not successful. Can someone elaborate on the way to get the right Password and User combination?
The help of this awesome community would be much appreciated.
Hi Commode,
it’s really easy if you would use an app on Android where you have installed Eurotronic App.
1.Make an Eurotronic account and log in.
2.Get an App - https://play.google.com/store/apps/details?id=com.minhui.networkcapture
set as a source that App and you can see all your unencrypted MQTT traffic data to external Server - mqtt.eurotronic.io.
3.Create in mosquitto new user with your settings (login/password) and it should work. :slight_smile:
Thank you very much! :+1:
I have successfully integrated the Comet WiFi into Home Assistant. I wrote a blog post about it:
@HelgeB
Thanks for youre template for sensor and device, that is what I needed for the thermostats. I added the Wifi Signal Strength as a sensor with the following:
  - name: Heizung Test Wifi
    object_id: comet_test_wifi
    unique_id: sensor.comet_test_wifi
    device:
      identifiers: ["02/0000XXXX/MAC-ADDR"]
    device_class: signal_strength
    unit_of_measurement: "dB"
    state_topic: 02/0000XXXX/MAC-ADDR/V/B3
    value_template: "{{ int(value[1:]) }}"
Also for the option to check if the setting “Open Window” is set:
switch:
  - name: Heizung Test Open Window
    object_id: comet_test_open_window
    unique_id: sensor.comet_test_open_window
    device:
    command_topic: 02/0000XXXX/MAC-ADDR/S/A5
    state_topic: 02/0000XXXX/MAC-ADDR/V/A5
    payload_on: "#140A"
    payload_off: "#040A"
This option can be used, but after set with Home Assistant it may need a manual call with “/S/AF” topic and #FFFFFFF payload. After this it shows the correct value with the switch.
Also if anyone need it, I figured out that you can call just battery, keylock, summertime and rotation settings with this:
Topic: 02/0000XXXX/MAC-ADDR/S/AF
Payload: #48000000
