I see there are lots of threads about this here, but I did not find the correct thread with information for me.
I have done the initial setup, but since I am running Windows I was not able to see the filesystem of the memory card after I loaded the image onto it.
I do not have a USB memory stick that I want to format to change the name right now. I tried just adding a folder called CONFIG to a general memory stick with other stuff on it, but it did not work.
I am wondering if there is a file I can edit with the configurator over LAN to set up the wifi manually or if I can do it with a screen and a keyboard instead.
are you using HA on windows? On a Raspberry Pi?
I can’t understand your setup.
