Looking to trigger an automation to so something (inside ESP, not a HA automation) when wifi connection is lost. I’ve seen the wifi signal sensor, but what’s the value I’m looking for when signal is gone?
Thanks!
Thanks!
Thanks; however Tasmota won’t suit my needs on this one, looking for an ESPHome solution!
This will turn off a switch if connection to HA is lost, whatever the reason
text_sensor:
- platform: homeassistant
name: "Uptime from Home Assistant"
entity_id: sensor.time
on_value:
then:
- lambda: !lambda |-
auto time_now = id(homeassistant_time).utcnow();
id(last_value_from_ha) = time_now.timestamp;
interval:
- interval: 15s
then:
- if:
condition:
if(time_now.timestamp - id(last_value_from_ha) > 120)
return true;
return false;
then:
- switch.turn_off: ventil # lost connection, turn off
time:
globals:
- id: last_value_from_ha
type: int
initial_value: '0'
Exactly what I was looking for. Great!
Many thanks.
Sorry to resurrect an old one. How do I use the inverse of this i.e. a condition if wifi.connected is false?
Thanks!
You might use the “else” case, not just the “then”.
Now there’s a facepalm moment. Thanks!
