I need to place a wifi temp & humidity sensor in a small building in my back garden and I have nothing that far that zigbeen can reach so it has to be wifi (and mains powered is fine also)
It needs to be able to talk to HA ofc.
I would play around with that usually but I need something ASAP that is basically plug and play.
Anyone know if the Sonoff TH16 is compatible with EweLink integration? I have that up and running for another generic wifi switch so that would be perfect.
I honestly believe you can set that up in about the same time as a pre built thing.
You still need the configuration in Home Assistant and/or in the app.
Maybe have a closer look at Shelly H&T. I do not have experience with this device but other Shelly devices integrate easily with HA via local API and Stock firmware afaik.
Mine are flashed with Tasmota.
