WIFI to Wired Setup
Running HassOS off the WIFI until I could find the Ethernet cable that was somewhere.
Now that it is setup over WIFI how do I change it to a wired connection or is that a reinstall?
Just change the MACs of IPs you allot in your router and are spread in your yamls
Just remove the Pi MAC address in my router?
No, I just meant that when you set up HA, you normally reserve the same internal IP address for it in your router; and now that you want to change from the PI’s wireless to wired LAN, the MAC address of the wired device will be the one where you bind the same internal IP address you would have previously bound to the wireless MAC
Oh right. I’m with you know. Thanks! That shall be my weekend project.
