Here is how I made a leak sensor, its now sitting under my kitchen sink
You donāt need the water sensor module. The inputs are sensitive enough without it, as long as you use a very week pull-up resistor. I found 3.9M Ohm worked best.
Thanks again man! I think Iām getting close!
Nice photo editing btw
I had to change the code a bit (of the testing firmware) for it to be reset itās state after a few seconds for testing again (otherwise it will stay down forever until a complete on-off, even reset wonāt clear itās state)
Problem is, itās not being reset-ed. I have to phisically disconnect the gpio jumper and return it for it to be able to detect again.
I mean- it detects the leakage only once, reset button wont work, only power down or pulling out and in the gpio jumper.
Any suggestion about that?
I guess it could work that way, accept i will have to pull it out of the power plug when i want to reset it (like an event of a leakage)
Attaching it here if anyone is interested:
#include <Arduino.h>
void setup(){
Serial.begin(115200);
pinMode(D5, OUTPUT);
pinMode(D2, INPUT);
void loop(){
int sensor=digitalRead(D2);
Serial.println(sensor);
if(sensor==LOW){
digitalWrite(D5, HIGH);
delay(5000);
digitalWrite(D2, HIGH);
digitalWrite(D5, LOW);
}else{
delay(250);
I did the sketch with TinkerCad https://www.tinkercad.com/
Now moving on to esphome:
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: "*****"
password: "*****"
manual_ip:
static_ip: 192.168.1.10
gateway: 192.168.1.1
subnet: 255.255.255.0
logger:
level: WARN
api:
ota:
binary_sensor:
- platform: status
name: "Kitchen Leak Status"
- platform: gpio
pin:
number: D2
inverted: True
on_press:
then:
- switch.turn_on: flod1_status_led
on_release:
then:
- switch.turn_off: flod1_status_led
- platform: wifi_signal
name: "Kitchen Leak WiFi Signal"
update_interval: 15s
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 15
send_first_at: 15
icon: mdi:wifi
switch:
- platform: gpio
name: Flod sensor 1 status led
pin:
number: D4
Thatās my config for the esphome node.
It act the same as the arduino one, as expected.
Thank you so much for your help, you are awesome!!
Your indentation is bit off:
on_press:
then:
on_release:
then:
Should be:
on_press:
then:
on_release:
then:
Donāt think thatās your issue though.
Mine definitely resets as soon as the probe is removed from the water. Try a slightly lower resistance, remove one of your 1M resistors.
Yeah I think thatās not the issue but thanks for noticing
I tried to remove one by one, also with no resistors, same result. so weird.
Noob alert, sorry, I donāt know much about electronics but just an assumption, maybe it has something to do with this capacitor being charged for the first time and then not being discharged when the short breaks?
Or maybe my probe has an internal capacitor???
Bought it from here:
Couldnāt find any information or datasheet on this probe. I assume itās dumb, but who knowsā¦
No capacitor. Thatās just a cable connected to some electrodes.
Youāve got it back to front.
The capacitor charges through the weak pull up resistor which is detected as a high logic level on the gpio. The water shorts out the capacitor. Which is detected as a logic low on the gpio and turns on the LED. When the water is removed the capacitor charges up again via the weak pull-up resistor which is detected as a high logic level.
If the capacitor is not charging the input could be floating. When you removed a resistor you did connect the resistor chain back up didnāt you? You did not leave it open circuit?
Sure I did, not that kind of noob
Iāve tried to replace the capacitor for a new one - same issue.
Tried a smaller one - same issue.
So I think we are on to the issue but I have 0 clue how to resolve it
Take a close up photo of your breadboard.
BTW, Iāve tried to short the two wires that connects to the probe to see what happens - it behaves exactly the same so I guess itās not the probe.
Sometimes touching it again will detect low, but randomly, sometimes even touching one of the wires (which is really weird).
Your circuit looks ok. Though for a high impedance circuit like this you really should keep the wires as short as possible to prevent picking up noise. Anyway, assuming you donāt live next door to an AM broadcast stationā¦
I only tested this on an ESP32, you are using an ESP8266. So we may have to adjust the resistor value to one that works.
The good news is that it is detecting water. We just need it to reset. To do that we need to incrementally reduce the resistor value from 3.9M Ohms down to some other value.
If you go too low the probe will stop detecting water.
If you are too high it wonāt reset.
We have a starting point of 3.9M, reduce that in half to 2M. Does it still detect water? If so reduce the resistor by half again to 1M. Does it still detect waterā¦? Keep doing this halving of the previous resistance until it does not detect water. Do not go to 0 Ohms. Then step up by a 1/4 of the previous value. So if it worked at 1M but did not detect water at 500K Go to 750K. Find the point where it just detects water. Does it reset when you remove water from the probe tips? Try increasing the resistance a bit more, does it still reset?
Find a point where it reliably detects water and resets. That is how I did it originally and found 3.9M worked well for my ESP32 boards.
Wellā¦ stepped it down one at a time, way down to 100K Ohms resistorā¦
OH BOY!
So anyone that want to do it with a D1 mini or I guess any other esp8266 based board that isnāt very fancy, as far as I can tell, should use a ~100K resistor
Thank you so much for your dedication to help others and give so much of your time, itās very much appreciated!
** I will solder the components onto a demo pcb and will print a 3d case for it, I will post here the results
Iām really surprised there is such a difference between the ESP32 and ESP8266 I/O. Great that you got it working though
tom_I, thank you for sharing this project and being so responsive with help. Iām entirely new to stuff like this, so forgive me if this post isnāt helpful, but is there any reason not to just stick two bare wires into a sponge for the sensor? I have two like that right now on my ESP32 that seem to be working fine. I was unable to detect water using stainless steel probes (maybe my config is wrong) so thatās why Iām using this method instead.
Here is my config:
esp32_touch:
iir_filter: 10ms
binary_sensor:
- platform: status
name: "Kitchen Sink Sensor Status"
- platform: gpio
pin:
number: GPIO27
mode: INPUT_PULLUP
inverted: True
- platform: gpio
pin:
number: GPIO32
mode: INPUT_PULLUP
inverted: True
name: "Kitchen Sink Leak"
- platform: gpio
pin:
number: GPIO33
mode: INPUT_PULLUP
inverted: True
I originally wanted to detect when the dogās water bowl got below a certain level using the stainless steel probes. Since that didnāt work I was able to instead use a reed float switch Iāll include the link for if anyone else is interested. The kitchen sink and dishwasher leak sensors were just a bonus since I already had an ESP32 in the same area.
https://www.amazon.com/gp/product/B07PZBK5T9/ref=ppx_yo_dt_b_asin_title_o08_s01?ie=UTF8&psc=1
Minus the sponge thatās exactly what I am doing. Using the touch sensor instead of just relying on water to short the probes should be a bit more sensitive for pure water. Using dosed town water or well water with dissolved solids should work either way.
Did you watch the values reported in the logger and set an appropriate threshold for the touch sensors?
Also for more than one touch sensor you need to remove this:
iir_filter: 10ms
Sorry, Iām not exactly sure what you mean by setting the threshold for the touch sensors or the values reported in the logger. The ESPHome logs only show whether the sensor state was ON or OFF.
Maybe Iām not configuring them properly as touch sensors? Because I have three of them on the same ESP32 board that are working without removing the iir_filter: 10ms
line.
And thanks for the incredibly quick reply!
Iāve played around a little and found out that the analog pin can be used too
So here is what Iāve ended up doing:
Thankās for all the help @tom_l!
Nice write up, thankās a lot for this!
Just build a leak detector based on a d1 mini and Iām having trouble to detect water. Using a 100k resistor like mentioned letās the probes react on metal but no luck for me with tap water .
Guess I now need to increase the resistor value again till I can detect water - is that right @tom_l?
Thanks so much for this. I built one and installed it in the basement, by the bulkhead door, where we have had leaks in the past. It works great!
