I would love for there to be a card where you could specify a wildcard for the entities that get displayed. Or just have the ability to use wildcards in entity selection. For example, if I would like to have a single card with all of my motion sensors displayed on it:
- type: entities
title: All Motion Sensors
wildcard_entities: binary_sensor.*_motion_sensor
Or something like that. I have several use cases:
Easily make a list of all motion or door sensors as a security card. Could be combined with a filter to only show the ones that are active
Card with all automations listed, to be able to easily disable ones during guests/parties/maintenance
Card will all lights, combined with filter to only show the ones that are on
Stuff like that.
JTPublic
(JT)
October 14, 2018, 1:23am
2
Take a look at monster-card , may be what you’re after.
jaburges
(jamieB)
October 14, 2018, 1:46am
3
i use an entity card, but have a single sensor for
all doors
all motion
all locks
the locks sensor will show something like this:
Back Door, Front door & Utility Door Unlocked
Here is an example of the sensor.motion_summary:
sensors:
motion_summary:
value_template: >
{%-for state in states.binary_sensor
if(state.attributes.device_class=="motion" and state.state=="on")-%}
{%-if loop.last-%}
{%-if loop.index > 0-%}
{%-for state in states.binary_sensor if(state.attributes.device_class=="motion" and state.state =="on")-%}
{{state.name}}{%-if not loop.last -%}{%-if(loop.index+1==loop.length)%} & {%else%}, {%endif-%}{%-else%} active{%endif-%}
{%-endfor-%}
{%-endif-%}
{%-endif-%}
{%-else-%}
all clear
{%-endfor-%}
icon_template: >
{%-if loop.last-%}
mdi:run-fast
{%-endif-%}
{%-endif-%}
{%-else-%}
mdi:check
{%-endfor-%}
Great scott! That’s exactly what I was after!
Thank you, @JTPublic !
xbmcnut
(xbmcnut)
November 21, 2018, 5:25am
5
Anyone have the skills to tweak that code to summarize devices with either say attributes.device_class
= battery or with attributes.battery_level
and a value below 75? Trying to find an easy way to summarise all battery powered devices into one notification without going to the full on MQTT discovery battery_levels package thingy.
myle
(StePhan McKillen (Other kiwi Here))
February 21, 2019, 6:34am
6
What am I missing
I have
sensors:
motion_summary:
value_template: >
if(state.attributes.device_class=="motion" and state.state=="on") -%}
{%-if loop.last-%}
{%-endfor-%}
{%-endif-%}
{%-endif-%}
{%-else-%}
all clear
{%-endfor-%}
icon_template: >
{%-if loop.last-%}
mdi:alert
{%-endif-%}
{%-endif-%}
{%-else-%}
mdi:check
{%-endfor-%}
all it show me is all clear
if put in the tempate thing
but in the front end I see all clear
which manual should i be reading
thanks
Your indentation is all messed up. I’m not an expert in Jinja, but I know in the YAML files, indentation matters. Look at the example a few posts above yours.
I know it’s been years but as a new HA user i came across this thread while searching for a good way to display low battery devices.
I’ve got it working now using the example above. Here are my 4 templates for doors, locks, motion and battery.
#### COMBINED MOTION/LOCK SENSORS #####################################################
#### Source: https://community.home-assistant.io/t/wildcard-entities-card/72969/3
sensors:
motion_summary:
value_template: >
{%-if loop.last-%}
{%-endfor-%}
{%-endif-%}
{%-endif-%}
{%-else-%}
No motion
{%-endfor-%}
icon_template: >
{%-if loop.last-%}
mdi:run-fast
{%-endif-%}
{%-endif-%}
{%-else-%}
mdi:motion-sensor-off
{%-endfor-%}
door_summary:
value_template: >
if(state.attributes.device_class=="opening" and state.state=="on")-%}
{%-if loop.last-%}
{%-for state in states.binary_sensor if(state.attributes.device_class=="opening" and state.state =="on")-%}
{{state.name}}{%-if not loop.last -%}{%-if(loop.index+1==loop.length)%} & {%else%}, {%endif-%}{%-else%} open{%endif-%}
{%-endfor-%}
{%-endif-%}
{%-endif-%}
{%-else-%}
All closed
{%-endfor-%}
icon_template: >
{%-if loop.last-%}
mdi:door-open
{%-endif-%}
{%-endif-%}
{%-else-%}
mdi:door-closed-lock
{%-endfor-%}
lock_summary:
friendly_name: Lock Summary
value_template: >
{%-for state in states.lock
if state.state== "unlocked" -%}
{%-if loop.last-%}
{%-for state in states.lock if state.state == "unlocked" -%}
{{state.name | replace('Lock', '')}}{%-if not loop.last -%}{%-if(loop.index+1==loop.length)%} & {%else%}, {%endif-%}{%-else%} unlocked{%endif-%}
{%-endfor-%}
{%-endif-%}
{%-endif-%}
{%-else-%}
All locked
{%-endfor-%}
icon_template: >
{%-if loop.last-%}
mdi:lock-alert-outline
{%-endif-%}
{%-endif-%}
{%-else-%}
mdi:lock-check-outline
{%-endfor-%}
#### LOW BATTERY SENSOR ###############################################################
sensors:
low_battery_summary:
value_template: >
{%-for state in states.sensor if(state.attributes.device_class=="battery" and state.state | int <= 25)-%}
{%-if loop.last-%}
{{state.name}}{%-if not loop.last -%}{%-if(loop.index+1==loop.length)%} & {%else%}, {%endif-%}{%-else%} low{%endif-%}
{%-endfor-%}
{%-endif-%}
{%-endif-%}
{%-else-%}
Everything is charged
{%-endfor-%}
icon_template: >
{%-if loop.last-%}
mdi:battery-10
{%-endif-%}
{%-endif-%}
{%-else-%}
mdi:battery
{%-endfor-%}
This type of functionality should really be packaged into a component that is more consumable for casual users. I read that entity-filter
used to something similar, but that functionality was removed. It’s really a shame because having the ability to do wildcards on entity name/id’s would make HomeAssistant a lot more usable and approachable.
Update: Looks like lovelace-auto-entities
. will do the trick!
I haven’t tried it yet, though.
