I am planning on getting a zigbee stick for sensors such as door contacts, temperature and humidity sensors or motion detectors, and also my existing Phillips Hue lights and a dimmer switch from Hue (which are currently used over the bridge via Hue integration).
I’ve seen that direct bindings between devices can be created in ZHA, which, I assume, are really directly from remote to device and thus still work in the case of a HA downtime or coordinator failure.
I have recently installed a Sonoff Zigbee 3.0 Dongle via ZHA and my first test was unplugging the stick and then checking if the HUE Remote I bound to some lights (also Hue) still works, and
It DOES indeed work even with coordinator unplugged
