Will Home Assistant run on the Raspberry Pi Zero W?
I am just wondering will Hassbian and/or HASS.IO run on the Raspberry Pi Zero W?
I have run hassbian in the past.
Definately slower than my Pi 3 during setup and when restarting but it functioned just fine for the small set of components I had on it.
Hassio apparently runs but you won’t like the experience…
I’m using Hassbian on my Pi Zero WH. It runs OK. But CPU often boots to 100%.
Hassbian will run on a RPI Zero or Zero W.
Some plugins and so on aren’t compatible with the Pi Zero and Zero W.
For a smaller setup a Pi Zero will be ok but as soon as your setup grows your going to want a faster Pi.
