But I wonder if it will create a problem polling as often as every 5 ms? Or doesn’t it matter? Could I even go to 1 ms without problems? I need to capture changes in this as fast as I possibly can, so I won’t slow down the script that’s dependant on it.
Thanks! So if I understand that correcly (which I didn’t when I read it, mhz doesn’t tell me anything…) does that mean 1 ms samples for ADC works? That’s 1000 times per second with wifi, right? But is this when there’s only one thing running on it? I have several relays and other sensors on the same ESP32.
