please help turn this
S:CLOSED,P:1,N:“Hallway PIR”
S:OPEN,P:1,N:“Hallway PIR”
into a workin
state_topic: Paradox/ZS/Z1
payload_on: “ON”
payload_off: “OFF”
Web Page info below
If successfully connected to your IP150 and MQTT broker, the app will start off by publishing all current zone and partition statuses. The following topics are available (and their names are configurable in the config.ini file):
Zone Statuses:
Topic: Paradox/ZS/Z1
(ZS = Zone Statuses; Z = Zone; followed by the number that has changed)
Payload (example): S:OPEN,P:1,N:"Front PIR"
(S = Status: OPEN / CLOSE (configurable in the config.ini file); P = Partition number, followed by the zone name)
Alarm Statuses:
Topic: Paradox/AS/P1
(AS = Alarm Status (Arm, Disarm, etc.); P = Partition, followed by the partition number)
Payload (example): Disarmed
(Possible states = Disarm, Arm, Sleep, Stay, Unsure)
config.ini info below
[MQTT Broker]
IP: 10.0.0.23
Port: 1883
[MQTT Topics]
Topic_Publish_Zone_States = Paradox/ZS
Payload_Publish_Zone_States_1 = OPEN
Payload_Publish_Zone_States_0 = CLOSED
Topic_Publish_Alarm_States = Paradox/AS
Topic_Publish_Siren_Status = Paradox/SS
Topic_Subscribe_Control = Paradox/C/
Random attempts at configuring config.yaml below
Things that do work are Sonoff Master Bed light
Arm and Disarm of alarm but don’t get status updated in home assistant
light:
- platform: mqtt
state_topic: “stat/sonoff/POWER”
command_topic: “cmnd/sonoff/power”
qos: 0
payload_on: “ON”
payload_off: “OFF”
optimistic: false
retain: true
binary_sensor:
platform: mqtt
state_topic: “Paradox/ZS/Z3”
Event_OK: “0”
Event_open: “1”
qos: 0
retain: true -
platform: mqtt
payload_on: "S:OPEN,P:1,N:“Theater_PIR”
payload_off: "S:Closed,P:1,N:“Theater_PIR”
qos: 0
retain: true -
platform: mqtt
qos: 0
retain: true -
platform: mqtt
payload_on: “S:OPEN,P:1,N: Theater_PIR”
payload_off: “S:Closed,P:1,N: Theater_PIR”
qos: 0
retain: true -
platform: mqtt
state_topic: “Paradox/ZS/Z1”
payload_on: “OPEN”
payload_off: “CLOSED”
qos: 0
retain: true -
platform: mqtt
payload_on: “OPEN”
qos: 0
retain: true -
platform: mqtt
payload_on: “OPEN”
qos: 0
retain: true
switch:
platform: mqtt
state_topic: “Paradox/AS/P1”
command_topic: “Paradox/C/P1/Arm”
payload_on: “Arm”
payload_off: “Disarmed”
qos: 1
retain: true -
platform: mqtt
state_topic: “‘Paradox/AS/P1’”
command_topic: “Paradox/C/P1/Disarm”
payload_on: “Arm”
qos: 1
This is my MQTT output by using this command mosquitto_sub -d -u pi -P 1234 -t "#"
[CODE]
Client mosqsub/7600-raspberryp sending CONNECT
Client mosqsub/7600-raspberryp received CONNACK
Client mosqsub/7600-raspberryp sending SUBSCRIBE (Mid: 1, Topic: #, QoS: 0)
Client mosqsub/7600-raspberryp received SUBACK
Subscribed (mid: 1): 0
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r1, m0, ‘tele/sonoff/LWT’, … (6 bytes))
Online
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r1, m0, ‘cmnd/sonoff/power’, … (2 bytes))
ON
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r1, m0, ‘Paradox/C/P1/Disarm’, … (3 bytes))
Arm
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r1, m0, ‘Paradox/C/P1/Arm’, … (3 bytes))
Arm
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/C/P1/Arm’, … (3 bytes))
Arm
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/AS/P1’, … (10 bytes))
Exit Delay
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/C/P1/Disarm’, … (3 bytes))
Arm
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/AS/P1’, … (11 bytes))
Unsure: (8)
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/ZS/Z3’, … (26 bytes))
S:OPEN,P:1,N:“Theater PIR”
Unsure: (9)
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/ZS/Z3’, … (28 bytes))
S:CLOSED,P:1,N:“Theater PIR”
Unsure: (8)
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/ZS/Z1’, … (30 bytes))
S:OPEN,P:1,N:“Living Room PIR”
Unsure: (9)
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/ZS/Z1’, … (32 bytes))
S:CLOSED,P:1,N:“Living Room PIR”
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/ZS/Z2’, … (26 bytes))
Unsure: (8)
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/ZS/Z2’, … (28 bytes))
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/ZS/Z7’, … (30 bytes))
S:OPEN,P:1,N:“PERIMETER DOORS”
Client mosqsub/7600-raspberryp received PUBLISH (d0, q0, r0, m0, ‘Paradox/ZS/Z7’, … (32 bytes))
S:CLOSED,P:1,N:“PERIMETER DOORS”
Unsure: (9)
Unsure: (8)
Unsure: (9)
[\CODE]
Ive tried all sorts of random stuff trying to stick to how the working sonoff is configured but just cant work out how to configure the binary sensors to update the states
