Will not install on a clean OS
This package requires Rust and Cargo to compile extensions. Install it through the system's package manager or via https://rustup.rs/
Pretty clear huh ?
I had the same on Raspberry Pi OS with the latest HA core built. Install Rust. Problem solved.
I got some of the install progress just before the error
Python 3.9.2 if looked at correctly
The error whined about cargo and rust neither solved the issue so apparently the proper steps is where I am failing
I thought so but didn’t work
Yes it does…
Ok then post up the proper steps of when and how to install them because I am apparently doing it wrong
Jesus… Did you even follow the link the error gave you ? There’s literally a step by step guide there…
  • Switch to whatever user you run hass as
  • curl https://sh.rustup.rs -sSf | sh
  • wait
  • try run rustc and cargo from the command line to see if it works - as the user you run hass as.
done.
Ok good luck.
Thanks for your help
If I may…
At this point, from the errors and logs and things you have been through, the HA core install method might not be the best method for you.
And if you agree to the above, I’d maintain my recommendations on #17 of this thread.
Now, there are other questions in this threads so far we do not yet have answers for. Let us know when you have the answers, and then we will figure out how to help.
Also. Let’s be civil and stop calling anyone clowns. I mean, it’s certainly OK if you think anyone a clown, but you can always choose to keep it to yourself, control your responses, carefully craft what you actually want to say/ask, so that to stay on topic, isn’t it?
Intel i7, 16 gigs of ram, 256 ssd
Home assistant was the only thing on it
I. Use to run proxmox and have clone copies of different stages of home assistant in case of failure
For the last year been running on bare metal direct
After this failed install I am back into proxmox so I can clone a new test machine more efficiently until I find a path to a successful install
After this failed install I. Tried to. Use haos every download of it was corrupt and fails to write to multiple known USB sticks so I decided to go back to what I am familiar with and muck about until I find a solution
The image then was probably corrupted while you were downloading it. Do you checked the sha256sum or how you have certainty the image file were corrupted? Also which type of storage do you use to save the file? Could be also a corrupted filesystem or drive :thinking:
Wasn’t interested enough in Haos to Pursue yet another headache if it was proper I might have used it until I figure out what broke core
Sigh. Alright. You get this error because some HA core component uses code written in Rust. And it needs a Rust compiler to compile it. And you don’t have that. The latest HA core will not function without a Rust compiler. So you need to install one.
That compiler needs to be available from the user you run hass as. That’s extremely important. Open a console and switch to the user you created for running hass. If you followed the tutorial above, that would be the homeassistant user.
sudo -u homeassistant -H -s
Now try to run the Rust compiler to see if it’s available.
rustc
It should say something like this:
if instead it says command not found, then you did not install Rust. Redo the steps I posted above. Do them as the user you run hass on.
Then try to run rustc again, as that user. As long as rustc doesn’t work, HA core will not work.
Edit: oh and yeah I agree, HA core is not the right install method for you. Don’t take that as an offense.
Oh, wait, so you have working copies / clones of HA on proxmox already?
Is your proxmox environment working properly otherwise?
And just to be sure - those clones / copies are HAOS VM, correct?
If yes, would recommend you just turn one of those test HAOS VM’s (in proxmox) into production, and forget about the idea of running HAOS natively (and forget about any USB sticks)… your intel i7 box is (way) too powerful to run only HA anyways.
Good luck.
In the docs (Installation - Home Assistant) the core install method is listed for “experienced users”
:100:
No I haven’t used proxmox for last year because ha been working really stable and I wasn’t using it for anything else. Never used hoas I always used core since the early days of home assistant
Okay I will try this again when I get home from work thanks
I am thinking your on it I didn’t change to the home assistant user name I will verify when I get home
And core may not be the best install method for me but it was the only one I could get to work years ago so I stuck with it
