Hello community !
I have 2 Pi(4)s to separately manage my HVAC and lighting, etc.
I have ping set up to monitor the Pis in case either of them fails (with automations if it fails after a couple of minutes). The only issue I’ve had over the past couple of years running HA is a mere 2 hangs of the HA core.
If I use ping to check each Pi (obviously this is at the hardware level), will it still respond if the core HA has hung? What if it is the OS that fails? That’s really what I am trying to remediate as if a Pi fails that would doubtless be a catastrophic failure at that point.
TIA
Ron
