i many moons ago made a thermostat that can adjust my heat pump based on wind direction… worked fine
now i want to add wind speed to the mix but i get “unknown error” when i try to add another trigger
blueprint:
name: Smart Thermostat
description: 'Based on wind direction thermostat is set to max'
domain: automation
input:
weather:
description: Specify your weather sensor to get the current outside wind direction from.
selector:
entity:
domain: sensor
thermostat:
description: Specify your thermostat.
selector:
entity:
domain: climate
wind1:
description: "The ouside wind direction needs to be between this and the next"
default: 123.75
selector:
number:
step: 1
min: 0
max: 360
unit_of_measurement: °
wind2:
default: 236.25
selector:
number:
step: 1
min: 0
max: 360
wind3:
default: 236.25
selector:
number:
step: 1
min: 0
max: 360
temp_to_set:
default: 23
selector:
number:
min: 5
max: 30
notify_device:
description: The device must run the official Home Assistant app to receive notifications.
default: false
selector:
device:
integration: mobile_app
variables:
temperature: !input temp_to_set
platform: numeric_state
entity_id: !input weather
above: !input wind1
below: !input wind2
- repeat:
while:
- condition: numeric_state
above: !input wind1
below: !input wind2
sequence:
- service: climate.set_temperature
data_template:
entity_id: !input thermostat
temperature: "{{ temperature }}"
- domain: mobile_app
type: notify
device_id: !input notify_device
message: "Termostat sat til {{ temperature }}"
- delay:
hours: 6
minutes: 0
seconds: 0
milliseconds: 0
where do i screw up? i tried to simply add a 3rd trigger after:
above: !input wind1
below: !input wind2
