Greetings,
I’ve set up the National Weather Service integration to pull data from one of the NWS local stations. The data feed appears to work fine, however, the wind speed as reported from the integration appears to be several times that of what the station reports on the NWS site. I’m hopeful that this is just a configuration issue on my part and that someone else has come across the same problem and resolved it.
What I noticed:
Below is a screen shot taken this morning out of HA:
Wind speed is reported as being 37mph.
Below is the data as show on the NWS web site:
Note the difference in wind speed (37 above vs. 10) The reading time and the other sensor values all appear to be either the same or within a reasonable amount of variance.
I then did the same for another station with similar results:
HA values:
29MPH wind speed
NWS station data:
5.8MPH wind speed
As with the screenshots above, the wind speed appears quite a bit different while the other sensor values appear similar.
Just in case someone is wondering if perhaps the difference is due to wind gusts, I don’t think that is the case. Conditions right now are calm and as can be seen at the bottom of the NWS forecast in the first example (station KDVO), winds are only expected to peak at 11mph today which is far different from the 37mph reported out of HA.
Is there a configuration option or other setup task that I just missed with the integration? Has anyone else run into something similar and solved it?
thanks in advance for the help!
