WindHager integration
Hi guys,
are there any new hints …how to find the password?
I tried several options in the menu…but i (and the windhager technician i talked to) have no clue where i could find it.
Thank you for your help
Hello everyone,
I have the same problem - I have installed the Windhager Heater integration according to the instructions…
Only the last step fails - I don’t have the correct password either :frowning:
Can anyone else help here?
Kind regards
Philipp :hugs:
Hi everybody, kind a old thread but I read about this “workaround” to finding your password in some other forum.
  1. Go to https://connect.windhager.com/ and open your heater page.
  2. change the last portion of the URL “management” to “settings”
  3. you find the password-managment there
Example: change https://connect.windhager.com/systems/{some long id string}/management to https://connect.windhager.com/systems/{some long id string}/settings
Hi everyone, integration works nice for me, but after a few days it stopped to regularly updating the data. Once I click “reload” manually, it has all needed data.
Do you have any idea what I could do? In the logs I can see entries like
File "/config/custom_components/windhager/sensor.py", line 86, in native_value
    ret = float(self.coordinator.data.get("oids").get(self._oid))
ValueError: could not convert string to float: '-.-'
File "/config/custom_components/windhager/climate.py", line 127, in current_temperature
    return float(
File "/config/custom_components/windhager/climate.py", line 254, in current_temperature
    return float(self.coordinator.data.get("oids").get(self._prefix + "/0/0/1/0"))
I’m wondering why on reload the majority of the values are retrieved correctly. And why did it work initially. Does an error in device fetching lead to a failure for all entities?
(Windhager BioWin2)
I found that there have been 2 entities which failed on updating. This seemed to let the whole thing crash and all entities did not get any update. After I disabled those 2 entities, the other ones are updating regularly.
Hello
thanks for your contribution. I got a question to find the password on an Biowin 2 Pelletoven installed 2023 with sw version v3.31 hardware version D10 Type: BW102E
Blockquote 1. Go to https://connect.windhager.com/ and open your heater page.
Does your Webinterface looks like mine in the prnt screen?
Thanks a lot
F
or does it looks like on the manual …
thaks a lot
Hello Dear
I am just getting first time into HA. because no Binding available on openhab.
When I startet to work trough that topic already got problem.
the link doesn`t work. Could you give me a hunt on where I can find to work into it.
What I previously checked and seems to work with the Newest PLC/ IPC of windhager Software on Bio win 2 Touch Pelletheater.
Question how does I need to setup the Homeassistant to be able to use the ha-windhager/tree/main
System Configuration:
  • Disk Station synology DS224+ running on Docker with Onah 3
  • Binding with Beckhoff PLC CX9020 for HMI and Control
That works:
  • myconnect app on Iphone
Testes and works: presvious https://…
…connect.windhager.com/systems/xxxxxxxxxxxxxxxxxxxxxxxx/management
changed once loged in: managment to settings
…connect.windhager.com/systems/xxxxxxxxxxxxxxxxxxxxxxxx/settings
From here I got the Password:
From Here I got the Excel link: (https://forum.iobroker.net/assets/uploa )]`
when entering :http://…
…/api/1.0/datapoint/1/15/1/0/0/
got following result:
Blockquote{
 “maxValue”: “0.0”,
 “minValue”: “0.0”,
 “value”: “7.7”,
 “OID”: “/1/15/1/0/0/0”,
 “groupNr”: 0,
 “memberNr”: 0,
 “name”: “00-000”,
 “step”: “0.1”,
 “stepId”: 0,
 “subtypeId”: -1,
 “timestamp”: “2024-11-12 10:02:49”,
 “typeId”: 13,
 “unitId”: 1,
 “unit”: “°C”,
 “writeProt”: true
So this seems to work properly even myconnect from windhager is also connected.
I think that I goog news and windhager made finally the improvement von 21 century :wink:
Can you help by setting up the System?
thanks a lot.
kr f
