Description:
Annoyed of mosquito and other insects that are attracted to light in your house when a window is open and it’s dark outside? Well then the following automation might be useful.
Turn off active lights when a window is opened. As soon as the window is closed, turn these lights on again. The nice part of this blueprint is, that it will only turn on the lights that were active before the window was opened
Notes
You must make sure to select entities (green badges). Lights for areas and devices can’t be turned on again at the moment
The blueprint will wait max. 2h to close the window again before it cancels the execution
Blueprint
Source:
