kslb
(KSLBe)
December 21, 2019, 8:35am
1
I have Vektiva Smarwi window opening mechanism which is working greatly for more than 1 year and I’m controling it via HTTP command. Problem with HTTP curl post command is that is slow, and also you do not have the best feedback status. So I decided to migrate to MQTT protocol - So, I figerout that Vektiva Smarwi also support MQTT (more in down configuration screenshots) but I do not know how to define MQTT so that it will work as normal switch. For additional security I have also Zigbee Xiaomi sensor so that I am 100% sure that window is closed/opened.
HTTP command for opening / closing:
# VEKTIVA Smarwi - 192.168.3.106 - Podstrešno okno
- platform: command_line
switches:
vektiva_smarwi_switch:
command_on: "/usr/bin/curl -X POST http://192.168.3.106/cmd/open"
command_off: "/usr/bin/curl -X POST http://192.168.3.106/cmd/close"
friendly_name: Podstrešno okno
So, I make new switch based on MQTT protocol, but it’s not working.
- platform: mqtt
name: "Podstrešno okno (mqtt)"
state_topic: "ion/mqtt/%60019449682a/status"
command_topic: "ion/mqtt/%60019449682a/cmd"
availability_topic: "ion/mqtt/%60019449682a"
qos: 1
payload_on: "open;100"
payload_off: "close;100"
payload_available: "Online"
payload_not_available: "Offline"
retain: false
Vektiva SMARWI configuration:
The complete documentation for MQTT protocol is online here:
https://vektiva.gitlab.io/vektivadocs/en/api/mqtt.html
So, can anybody help me how to define switch correctly with this documentation…
I tested via Developer tools and it’s working (opening, closing) but, on switch I have problems.
My data for MQTT:
Device ID:
60019449682a
User:
mqtt
Command for opening:
ion/mqtt/%60019449682a/cmd -m “open;100”
Command for closing:
ion/mqtt/%60019449682a/cmd -m “close;100”
But for Developer tools I used withouth “-m” and it was working.
Thank you for you help…
kslb
(KSLBe)
December 22, 2019, 10:41am
2
So, can anybody help me to define the correct MQTT switch?
francisp
(Francis)
December 22, 2019, 1:37pm
3
What errors do you see in the log when you try your defined switch ?
Otherwise, if you can define a binary_sensor which indicates open (on) or closed (off), you can try a template switch
switches:
podstresno_oknok:
value_template: "{{ is_state('binary_sensor.my_binary_sensor', 'on') }}"
turn_on:
- service: mqtt.publish
payload: 'open;100'
topic:'ion/mqtt/%60019449682a/cmd'
turn_off:
payload: 'close;100'
topic: 'ion/mqtt/%60019449682a/cmd'
kslb
(KSLBe)
December 22, 2019, 2:26pm
4
I do not get any errors…
Just that MQTT is not “online”. In log file there is nothing about that…
The problem is in switch configuration:
- platform: mqtt
qos: 1
retain: false
So, I did not configure something correctly, because even icon is not correct, it should be as for switch for tasmota…
So, maybe I do not understand instructions on vektiva online site correctly…
francisp
(Francis)
December 22, 2019, 2:35pm
5
Then there is something wrong with the connection between your mqtt broker and HA. How did you install your mqtt broker ?
kslb
(KSLBe)
December 22, 2019, 2:46pm
6
My MQTT broker is OK, I have another 39 tasmota sensors and switches and all is working fine…
Also device is normally open and close via developer tools (screenshot)…
The only problem is that I do not know how to correctly define MQTT switch because I’m noob regarding that…
francisp
(Francis)
December 22, 2019, 3:15pm
7
The problem with trying to do it the ‘Tasmota’ way is the state_topic, it does not return a value or json but a list of key:value strings.
kslb
(KSLBe)
December 22, 2019, 3:36pm
8
OK… Yes… I was using the “Tasmota” way… So, is there any other way withouth use of binary_sensor?
kslb
(KSLBe)
December 22, 2019, 7:16pm
9
This way we can do it…
switches:
podstresno_oknok:
turn_on:
payload: 'open;100'
turn_off:
but rather then use some binary sensor we would read status via mqtt of device it’self…
kslb
(KSLBe)
December 22, 2019, 7:20pm
10
We know, that we can get position from:
“ion/mqtt/%60019449682a/#”
open:
pos:o
closed:
pos:c
So why not to use this instead of binary sensor? How to use it? How to set as switch buttton (not lighting symbol)?
francisp
(Francis)
December 23, 2019, 5:21am
11
You can probably define your binary sensor as this :
- platform: mqtt
state_topic: 'ion/mqtt/%60019449682a/status'
value_template: >-
{% if 'pos:c' in value %}
{{'OFF'}}
{% else %}
{{'ON'}}
{% endif %}
Tested with this jinja2 template :
Imitate available variables:
{% set my_test_json = "t:swr
s:200
e:0
ok:1
ro:0
pos:c
fix:0
a:0
fw:203.2.1
mem:19928
up:259284714
ip:285870602
cid:BedroomWindow
rssi:-63
time:1523292002"
{{ 'pos:c' in my_test_json }}
kslb
(KSLBe)
December 23, 2019, 9:37am
12
Great… It’s working… Thank you for providing solution… With that I can also manage that in case of any error I can add another binary sensor with window status (OK / NOT OK aka something is wrong).
My final configuration:
Binary sensor:
- platform: mqtt
name: Podstrešno okno (stanje)
value_template: >-
{{'OFF'}}
{% else %}
{{'ON'}}
{% endif %}
Switch:
switches:
vektiva_smarwi_podstresno_okno:
friendly_name: "Podstrešno okno"
value_template: "{{ is_state('binary_sensor.podstresno_okno_stanje', 'on') }}"
turn_on:
payload: 'open;100'
turn_off:
Also, I have backup Xiaomi sensor on window, so that I am 100% sure that sensor status is 100% correct.
kslb
(KSLBe)
January 10, 2020, 6:15am
13
Video which show how this is working…
dmatora
(Dmitry)
December 16, 2020, 9:09am
14
I tried suggested config and it didn’t work for me
after playing with it I came up with
- platform: mqtt
state_topic: 'ion/<USER>/%<DEVICE_ID>/status'
value_template: >-
{{'OFF'}}
{% else %}
{{'ON'}}
{% endif %}
and switch:
switches:
smarwi_playroom:
unique_id: window_playroom_switch
friendly_name: "Окно (Детская)"
value_template: "{{ is_state('sensor.window_playroom', 'ON') }}"
icon_template: >-
{% if is_state('sensor.window_playroom', 'ON') %}
mdi:window-open
{% else %}
mdi:window-closed
{% endif %}
turn_on:
payload: 'open;100'
topic: 'ion/<USER>/%<DEVICE_ID>/cmd'
turn_off:
And now it’s working.
I wonder if there is a way to make it percent selectable
dmatora
(Dmitry)
December 19, 2020, 11:35pm
15
Found a way, there is a custom integration of smarwi available for home assistant, which supports percentage - GitHub - cvrky/vektiva_smarwi_ha
It also support proper HomeKit integration (as a window, as opposed to blinds or a switch) when using home assistant as HomeKit bridge
I also followed HACS integration way. After installation I see “Vektiva Smartwi” in Integrations, but there is no ovbious way how to configure it…
Can you give me some hint, please?
kslb
(KSLBe)
November 9, 2022, 12:25pm
17
How did you configure your Vektiva device?
dmatora
(Dmitry)
January 20, 2023, 9:59am
18
Just go to integrations,
click add integration,
select “Vektiva Smarwi”
and fill in IP address
jirutka
(Jakub Jirutka)
May 1, 2024, 10:23am
19
I’ve created a custom Home Assistant integration for SMARWI that allows you to fully control SMARWI via a local MQTT broker. It’s much more advanced than cvrky/vektiva_smarwi_ha , easier to install and set up.
Supported features: open, close, stop, open to position, fix/release the ridge, report if the ridge is inside the device, and change finetune settings.
