Window open detection by temperature
An automation blueprint that detects a window opened for too long by the temperature setting and actual temperature of a climate device.
It reacts if the device target temperature is set to a "window open" temperature, e.g. by a window sensor or open window recognition of the climate entity.
Additionally, it reacts if the current temperature drops below a threshold.
It then waits for the duration, the window is allowed to be open.
After that it measures the room temperature and waits a recovery period, in which the temperature should rise again.
If the current temperature is still below both the temperatur when triggered and before the recovery period, a configurable action is performed.
The action can e.g. be to notify with a notification, the default shows an example.
begin/end_check_temp are variables that contain the temperture before and after the recovery period.
The automation is executed in single mode, so it will only be executed for one of the climate entities at a time.
blueprint:
  name: Window Open by Temperature
  description:
  domain: automation
  source_url: https://github.com/asoehlke/HomeAssistant/blob/a326a9034718cf976ab804f5249fc94ae17df363/BluePrints/Automation/WindowOpenByTemp.yaml
  input:
    allowed_open_time:
      name: Window maximum open time
      description: Maximum time the window should be open.
      default: 10
      selector:
        number:
          min: 0.0
          max: 30.0
          unit_of_measurement: minutes
          mode: slider
          step: 1.0
    recovery_time:
      name: Temperature recovery time
      description: Time during which the temperture should rise again after closing the window.
      default: 5
      selector:
        number:
          min: 0.0
          max: 30.0
          mode: slider
          step: 1.0
    max_open_temp:
      name: Maximum "window open" temperature setting
      description: Temperature setting below which a climate entity is considered to be in "window open" state.
      default: 14
      selector:
        number:
          min: 0.0
          max: 17.0
          unit_of_measurement: °C
          mode: slider
          step: 1.0
    min_room_temperature:
      name: Minimum room temperture with closed window
      description: If the room temperture falls below this value, the window is considered open.
      default: 16
      selector:
        number:
          min: 0.0
          max: 17.0
          mode: slider
          step: 1.0
    blocking_entity:
      name: (OPTIONAL) Blocking Entity
      description: If this entity's state is on, it will prevent the automation from running. E.g. summer mode or away mode.
      default:
      selector:
        entity:
          domain: input_boolean
    climate_entity:
      name: Climate Device (s)
      description: The climate entities that are controlled by the temperature.
      selector:
        entity:
          domain: climate
          multiple: true
    open_action:
      description: Action to perform if the door/window is open for too long (e.g. send notification). begin_check_temp and end_check_temp are the temperatures at start and end of the recovery time.
      default:
        - service: notify.telegramfamsoe
            message: >-
              Window near {{ state_attr(trigger.entity_id, 'friendly_name') }}
              open? Temperature now: {{ end_check_temp }}, {{ recovery_time }}
              min. ago: {{ begin_check_temp }}
      selector:
        action: {}
mode: single
variables:
  blocking_entity: !input blocking_entity
  allowed_open_time: !input allowed_open_time
  recovery_time: !input recovery_time
  max_open_temp: !input max_open_temp
  min_room_temperature: !input min_room_temperature
  - platform: state
    entity_id: !input climate_entity
    attribute: temperature
    to:
  - platform: state
    attribute: current_temperature
    to:
condition:
  - condition: template
    value_template: "{{ (blocking_entity == none) or (states[blocking_entity].state == 'off') }}"
  # use a condition instead of the "below" criteria in the trigger for two reasons:
  # - below does not support templates
  # - the automation should also be triggered again, if the windows remains open after the first run.
    value_template: "{{ trigger.to_state.attributes.current_temperature < min_room_temperature or trigger.to_state.attributes.temperature < max_open_temp }}"
  - variables:
      trigger_current_temp: '{{ trigger.to_state.attributes.current_temperature }}'
      climate_id: '{{ trigger.to_state.attributes.id }}'
  - delay:
      minutes: "{{ allowed_open_time }}"
  - variables:
      begin_check_temp: '{{ state_attr(trigger.entity_id, "current_temperature") | float }}'
  - delay:
      minutes: "{{ recovery_time }}"
  - variables:
      end_check_temp: '{{ state_attr(trigger.entity_id, "current_temperature") | float }}'
  # Only do further actions like notifications, if the window still seems open:
  # - Current temperature in recovery period must still have fallen.
  # - Current temperature must be below current temperature at trigger time.
  #   This prevents false alerts when a window sensor caused the open state for a very short time.
  - condition: "{{ end_check_temp < begin_check_temp and end_check_temp < trigger_current_temp - 0.5 }}"
  - choose:
    - conditions: '{{ open_action is defined and open_action|length > 0 }}'
      sequence: !input open_action
Great blueprint, I appreciate it. When I have multiple climate entities set, and multiple windows are left open, will it trigger multiple actions? If I get your info right,
it makes sense to have one automation for each climate device. It would also be favorable to have the option to set temperature sensors.
Hello @asoehlke, I have a similar question like @bas89.
I also really appreciate your blueprint.
I have also multiple climate in different rooms.
Do I must create one automatisation per room in this case with your blueprint?
It’s a little bit high management in this case …
Do you have a solution for this case?
Currently I get
"script_execution": "failed_conditions"
on condition/1
kind regards
Ricardo
