Window Open Raise HVAC temperature
This Automation is a Copy of @Govido Window Controlled Heater.
I have made some Easy modification for my need, because My thermostates only lets me see the temperature and change the set point. This system is a limited system because it used a combo of KNX and BACNET. I only have access to the KNX part of this system here on HA.
so what this does, once a window is opened it will raise the temperature to 26C, meaning that in the Summer the HVAC will stop because the temperature inside is Lower than 26. It will bring it back after a certain time defined by you, to whatever temperature it had
you can change all the code to spec your needs. I will make you as well for the Winter.
blueprint:
  name: window controlled heater
  description: Raise heater temp when opening window and turn on with delay
  domain: automation
  source_url: https://gist.github.com/govido/4aaa213e6209d3b76ec0e65d576e3701
  input:
    heating_target:
      selector:
        entity:
          domain: climate
    window_entity:
      selector:
        entity: {}
    window_closed_wait:
      name: Wait time open
      description: Time to leave the heating on after window or door is opened.
      default: 120
      selector:
        number:
          min: 0.0
          max: 3600.0
          unit_of_measurement: seconds
          mode: slider
          step: 1.0
    window_opened_wait:
      name: Wait time closed
      description: Time to leave the heating off after window or door is closed.
      default: 120
      selector:
        number:
          min: 0.0
          max: 3600.0
          mode: slider
          step: 1.0
mode: restart
max_exceeded: silent
variables:
  heating_target: !input 'heating_target'
  heating_temperature: '{{ state_attr(heating_target, ''temperature'') }}'
  platform: state
  entity_id: !input 'window_entity'
  to: 'on'
- delay: !input 'window_opened_wait'
- service: climate.set_temperature
  entity_id: !input 'heating_target'
    temperature: 26
- wait_for_trigger:
    platform: state
    to: 'off'
- delay: !input 'window_closed_wait'
    temperature: 23
    temperature: '{{heating_temperature}}'
