Hey there,
I am using the generic_thermostat
integration to handle my thermostats.
I currently working on extending the source code to get an optional window
sensor to be handled by the integration itself.
So what I am thinking about is
- have an optional
window_entity_id
to be configured - optional
window_open_duration
(default would be “instant”) - optional
window_open_temperature
(default might bemin_temp
? not sure 'bout this)
There are some things I am actually struggling with.
- do not handle window stuff when HVAC is turned off (that seems to be easy as I can just handle
HVAC_MODE_OFF
for it) - when window is opened, I want to wait until the
exceeds but
I dont get howmin_cycle_duration
works as there is no such “timer” stuff. - when window is closed, I want to restore previous temperature setting. But what would be the best way to persist previous temperature setting?
- when HA is rebooted while window handling is active, how could I restore entity states after restart so I can handle window close afterwards?
- do we even need it or should I just turn off the thermostat? when switching off thermostat at all, how could I make a difference betweenHVAC_MODE_OFF
because its summer vs.HVAC_MODE_OFF
because I’ve switched it off due to window detection?
I’d like to get some feedback here so I can move on with my python coding
Thanks in advance!
