I have window sensors which can have the following states: open, close, tilted
Now I would like to achieve two things:
- Visual indicator
I would like to show the state of the windows with an LED. If at least one window is tilted then I want to slowly slash, if at least one window is open, I would like to fast flash. Second automation override the first obviously. - TTS indicator
If you press a button (next to the LED) it should say
“The following windows are open” ${list of rooms with open windows}"
" the following windows are tilted" ${list of rooms with tilted windows}"
I can definitly manually “hack” this together somehow, but I wonder if there is an elegant solution with groups or helpers. Any hint is highly appreciated!
Best regards,
Jonas
