OK, the above solution don’t work. I have changed the sequence to:
Now I have the problem, that even though the temperature is above the 5 degrees, all shutters go down. What I make wrong by the temperature exits?
Also I still don’t know, how can I block the second tigger with the first one ![:frowning: :frowning:](https://community.home-assistant.io/images/emoji/twitter/frowning.png?v=9)
Can somebody help me?
[{"id":"c70e6ef0.37d27","type":"tab","label":"Rollos ersatz","disabled":false,"info":""},{"id":"505d8cc7.37bd54","type":"api-call-service","z":"c70e6ef0.37d27","name":"Küchen und Schlafzimmer Rollo auf 27%","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"cover","service":"set_cover_position","entityId":"cover.kuche_rollo, cover.schlafzimmer_rollo","data":"{\"position\":27}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1300,"y":120,"wires":[[]]},{"id":"10dc5e6e.823062","type":"api-call-service","z":"c70e6ef0.37d27","name":"Wohnzimmer Rollo auf 27%","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"cover","service":"set_cover_position","entityId":"cover.rollo_links","data":"{\"position\":27}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1420,"y":180,"wires":[[]]},{"id":"f4677fad.a0fcf","type":"api-call-service","z":"c70e6ef0.37d27","name":"Küchen und Wohnzimmer Rollo auf 100%","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"cover","service":"open_cover","entityId":"cover.kuche_rollo, cover.rollo_links","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1300,"y":260,"wires":[[]]},{"id":"a30116f2.59553","type":"within-time-switch","z":"c70e6ef0.37d27","name":"","nameInt":"","positionConfig":"c147288e.624ad","startTime":"sunset","startTimeType":"pdsTime","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"sunrise","endTimeType":"pdsTime","endOffset":"","endOffsetType":"none","endOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"tsCompare":"0","x":440,"y":40,"wires":[["999b9efb.abb64","1ebbc1cb.06f966"],["8b7dc871.6f625","70598897.367cf8"]],"icon":"node-red-node-suncalc/sun.png"},{"id":"43cbfd79.d87b24","type":"trigger-state","z":"c70e6ef0.37d27","name":"Temp draußen unter 5 Grad","server":"ad8e5e9e.dec0c","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityid":"sensor.temperatur_aussen_temperature","entityidfiltertype":"exact","debugenabled":false,"constraints":[],"outputs":4,"customoutputs":[{"messageType":"default","messageValue":"","messageValueType":"json","comparatorPropertyType":"current_state","comparatorType":"<=","comparatorValue":"5","comparatorValueDataType":"str","comparatorPropertyValue":"new_state.state"},{"messageType":"default","messageValue":"","messageValueType":"json","comparatorPropertyType":"current_state","comparatorType":">","comparatorValue":"5","comparatorValueDataType":"str","comparatorPropertyValue":"new_state.state"}],"outputinitially":false,"state_type":"str","x":140,"y":120,"wires":[[],[],["a30116f2.59553"],["b9c61c95.74258"]],"icon":"font-awesome/fa-thermometer-2"},{"id":"f1b2ba69.040f08","type":"api-call-service","z":"c70e6ef0.37d27","name":"Alle Rollos auf 0%","server":"ad8e5e9e.dec0c","version":1,"debugenabled":false,"service_domain":"cover","service":"close_cover","entityId":"cover.alle_rollos_shuttergroup","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1230,"y":40,"wires":[[]]},{"id":"2dbf1abd.2b5576","type":"weekday","z":"c70e6ef0.37d27","name":"weekend","sun":true,"mon":false,"tue":false,"wed":false,"thu":false,"fri":true,"sat":true,"x":1200,"y":180,"wires":[["10dc5e6e.823062"],[]]},{"id":"eb667754.daeb8","type":"trigger","z":"c70e6ef0.37d27","name":"","op1":"1","op2":"0","op1type":"pay","op2type":"val","duration":"0","extend":"false","units":"ms","outputs":1,"x":990,"y":120,"wires":[["505d8cc7.37bd54","2dbf1abd.2b5576"]]},{"id":"70598897.367cf8","type":"change","z":"c70e6ef0.37d27","name":"","rules":[{"t":"set","p":"reset","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":120,"wires":[["eb667754.daeb8","999b9efb.abb64"]]},{"id":"999b9efb.abb64","type":"trigger","z":"c70e6ef0.37d27","name":"","op1":"1","op2":"0","op1type":"pay","op2type":"val","duration":"0","extend":"false","units":"ms","outputs":1,"x":990,"y":40,"wires":[["f1b2ba69.040f08"]]},{"id":"8b7dc871.6f625","type":"trigger","z":"c70e6ef0.37d27","name":"","op1":"1","op2":"0","op1type":"pay","op2type":"val","duration":"0","extend":"false","units":"ms","outputs":1,"x":990,"y":260,"wires":[["f4677fad.a0fcf"]]},{"id":"1ebbc1cb.06f966","type":"change","z":"c70e6ef0.37d27","name":"","rules":[{"t":"set","p":"reset","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":160,"wires":[["8b7dc871.6f625"]]},{"id":"b9c61c95.74258","type":"within-time-switch","z":"c70e6ef0.37d27","name":"","nameInt":"","positionConfig":"c147288e.624ad","startTime":"sunset","startTimeType":"pdsTime","startOffset":0,"startOffsetType":"none","startOffsetMultiplier":60000,"endTime":"sunrise","endTimeType":"pdsTime","endOffset":"","endOffsetType":"none","endOffsetMultiplier":60000,"timeDays":"*","timeOnlyOddDays":false,"timeOnlyEvenDays":false,"timeMonths":"*","timedatestart":"","timedateend":"","propertyStart":"","propertyStartType":"none","propertyStartCompare":"true","propertyStartThreshold":"","propertyStartThresholdType":"num","startTimeAlt":"","startTimeAltType":"entered","startOffsetAlt":0,"startOffsetAltType":"none","startOffsetAltMultiplier":60000,"propertyEnd":"","propertyEndType":"none","propertyEndCompare":"true","propertyEndThreshold":"","propertyEndThresholdType":"num","endTimeAlt":"","endTimeAltType":"entered","endOffsetAlt":0,"endOffsetAltType":"none","endOffsetAltMultiplier":60000,"tsCompare":"0","x":440,"y":240,"wires":[["eb667754.daeb8","1ebbc1cb.06f966"],["8b7dc871.6f625","70598897.367cf8"]],"icon":"node-red-node-suncalc/sun.png"},{"id":"ad8e5e9e.dec0c","type":"server","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true},{"id":"c147288e.624ad","type":"position-config","name":"Neuss","isValide":"true","longitude":"0","latitude":"0","angleType":"deg","timeZoneOffset":99,"timeZoneDST":0,"stateTimeFormat":"3","stateDateFormat":"12"}]
