Hi All!
I’m having a bit of trouble installing Home Assistant directly to my Windows PC.
I’ve installed The latest Python build “python-3.9.0-amd64.exe” & and the latest C++Buildtools from the MS Visual Studios installer.
When I run:
py -m pip install homeassistant
I get this error when building wheel for Cryptography:
Building wheel for cryptography (PEP 517) ... error
ERROR: Command errored out with exit status 1:
command: 'C:\Users\BRODI\AppData\Local\Programs\Python\Python39\python.exe' 'C:\Users\BRODI\AppData\Local\Programs\Python\Python39\lib\site-packages\pip\_vendor\pep517\_in_process.py' build_wheel 'C:\Users\BRODI\AppData\Local\Temp\tmpc62gdltv'
cwd: C:\Users\BRODI\AppData\Local\Temp\pip-install-fl2m5e8j\cryptography
Complete output (137 lines):
running bdist_wheel
running build
running build_py
creating build
creating build\lib.win-amd64-3.9
creating build\lib.win-amd64-3.9\cryptography
copying src\cryptography\exceptions.py -> build\lib.win-amd64-3.9\cryptography
copying src\cryptography\fernet.py -> build\lib.win-amd64-3.9\cryptography
copying src\cryptography\utils.py -> build\lib.win-amd64-3.9\cryptography
copying src\cryptography\__about__.py -> build\lib.win-amd64-3.9\cryptography
copying src\cryptography\__init__.py -> build\lib.win-amd64-3.9\cryptography
creating build\lib.win-amd64-3.9\cryptography\hazmat
copying src\cryptography\hazmat\_der.py -> build\lib.win-amd64-3.9\cryptography\hazmat
copying src\cryptography\hazmat\_oid.py -> build\lib.win-amd64-3.9\cryptography\hazmat
copying src\cryptography\hazmat\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat
creating build\lib.win-amd64-3.9\cryptography\x509
copying src\cryptography\x509\base.py -> build\lib.win-amd64-3.9\cryptography\x509
copying src\cryptography\x509\certificate_transparency.py -> build\lib.win-amd64-3.9\cryptography\x509
copying src\cryptography\x509\extensions.py -> build\lib.win-amd64-3.9\cryptography\x509
copying src\cryptography\x509\general_name.py -> build\lib.win-amd64-3.9\cryptography\x509
copying src\cryptography\x509\name.py -> build\lib.win-amd64-3.9\cryptography\x509
copying src\cryptography\x509\ocsp.py -> build\lib.win-amd64-3.9\cryptography\x509
copying src\cryptography\x509\oid.py -> build\lib.win-amd64-3.9\cryptography\x509
copying src\cryptography\x509\__init__.py -> build\lib.win-amd64-3.9\cryptography\x509
creating build\lib.win-amd64-3.9\cryptography\hazmat\backends
copying src\cryptography\hazmat\backends\interfaces.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends
copying src\cryptography\hazmat\backends\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends
creating build\lib.win-amd64-3.9\cryptography\hazmat\bindings
copying src\cryptography\hazmat\bindings\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\bindings
creating build\lib.win-amd64-3.9\cryptography\hazmat\primitives
copying src\cryptography\hazmat\primitives\cmac.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives
copying src\cryptography\hazmat\primitives\constant_time.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives
copying src\cryptography\hazmat\primitives\hashes.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives
copying src\cryptography\hazmat\primitives\hmac.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives
copying src\cryptography\hazmat\primitives\keywrap.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives
copying src\cryptography\hazmat\primitives\padding.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives
copying src\cryptography\hazmat\primitives\poly1305.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives
copying src\cryptography\hazmat\primitives\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives
creating build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\aead.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\backend.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\ciphers.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\cmac.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\decode_asn1.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\dh.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\dsa.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\ec.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\ed25519.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\ed448.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\encode_asn1.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\hashes.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\hmac.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\ocsp.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\poly1305.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\rsa.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\utils.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\x25519.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\x448.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\x509.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
copying src\cryptography\hazmat\backends\openssl\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\backends\openssl
creating build\lib.win-amd64-3.9\cryptography\hazmat\bindings\openssl
copying src\cryptography\hazmat\bindings\openssl\binding.py -> build\lib.win-amd64-3.9\cryptography\hazmat\bindings\openssl
copying src\cryptography\hazmat\bindings\openssl\_conditional.py -> build\lib.win-amd64-3.9\cryptography\hazmat\bindings\openssl
copying src\cryptography\hazmat\bindings\openssl\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\bindings\openssl
creating build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\dh.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\dsa.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\ec.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\ed25519.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\ed448.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\padding.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\rsa.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\utils.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\x25519.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\x448.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
copying src\cryptography\hazmat\primitives\asymmetric\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\asymmetric
creating build\lib.win-amd64-3.9\cryptography\hazmat\primitives\ciphers
copying src\cryptography\hazmat\primitives\ciphers\aead.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\ciphers
copying src\cryptography\hazmat\primitives\ciphers\algorithms.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\ciphers
copying src\cryptography\hazmat\primitives\ciphers\base.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\ciphers
copying src\cryptography\hazmat\primitives\ciphers\modes.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\ciphers
copying src\cryptography\hazmat\primitives\ciphers\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\ciphers
creating build\lib.win-amd64-3.9\cryptography\hazmat\primitives\kdf
copying src\cryptography\hazmat\primitives\kdf\concatkdf.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\kdf
copying src\cryptography\hazmat\primitives\kdf\hkdf.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\kdf
copying src\cryptography\hazmat\primitives\kdf\kbkdf.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\kdf
copying src\cryptography\hazmat\primitives\kdf\pbkdf2.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\kdf
copying src\cryptography\hazmat\primitives\kdf\scrypt.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\kdf
copying src\cryptography\hazmat\primitives\kdf\x963kdf.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\kdf
copying src\cryptography\hazmat\primitives\kdf\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\kdf
creating build\lib.win-amd64-3.9\cryptography\hazmat\primitives\serialization
copying src\cryptography\hazmat\primitives\serialization\base.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\serialization
copying src\cryptography\hazmat\primitives\serialization\pkcs12.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\serialization
copying src\cryptography\hazmat\primitives\serialization\ssh.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\serialization
copying src\cryptography\hazmat\primitives\serialization\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\serialization
creating build\lib.win-amd64-3.9\cryptography\hazmat\primitives\twofactor
copying src\cryptography\hazmat\primitives\twofactor\hotp.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\twofactor
copying src\cryptography\hazmat\primitives\twofactor\totp.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\twofactor
copying src\cryptography\hazmat\primitives\twofactor\utils.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\twofactor
copying src\cryptography\hazmat\primitives\twofactor\__init__.py -> build\lib.win-amd64-3.9\cryptography\hazmat\primitives\twofactor
running egg_info
writing src\cryptography.egg-info\PKG-INFO
writing dependency_links to src\cryptography.egg-info\dependency_links.txt
writing requirements to src\cryptography.egg-info\requires.txt
writing top-level names to src\cryptography.egg-info\top_level.txt
reading manifest file 'src\cryptography.egg-info\SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'docs\_build'
warning: no previously-included files found matching 'vectors'
warning: no previously-included files matching '*' found under directory 'vectors'
warning: no previously-included files found matching 'azure-pipelines.yml'
warning: no previously-included files found matching '.azure-pipelines'
warning: no previously-included files found matching '.travis.yml'
warning: no previously-included files found matching '.travis'
warning: no previously-included files matching '*' found under directory '.azure-pipelines'
warning: no previously-included files matching '*' found under directory '.travis'
warning: no previously-included files found matching 'release.py'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching 'codecov.yml'
warning: no previously-included files found matching 'dev-requirements.txt'
warning: no previously-included files found matching 'rtd-requirements.txt'
warning: no previously-included files found matching 'tox.ini'
writing manifest file 'src\cryptography.egg-info\SOURCES.txt'
running build_ext
generating cffi module 'build\\temp.win-amd64-3.9\\Release\\_padding.c'
creating build\temp.win-amd64-3.9
creating build\temp.win-amd64-3.9\Release
generating cffi module 'build\\temp.win-amd64-3.9\\Release\\_constant_time.c'
generating cffi module 'build\\temp.win-amd64-3.9\\Release\\_openssl.c'
building '_openssl' extension
creating build\temp.win-amd64-3.9\Release\build
creating build\temp.win-amd64-3.9\Release\build\temp.win-amd64-3.9
creating build\temp.win-amd64-3.9\Release\build\temp.win-amd64-3.9\Release
C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.27.29110\bin\HostX86\x64\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -IC:\Users\BRODI\AppData\Local\Programs\Python\Python39\include -IC:\Users\BRODI\AppData\Local\Programs\Python\Python39\include -IC:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Tools\MSVC\14.27.29110\include -IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\ucrt -IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\shared -IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\um -IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\winrt -IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\cppwinrt /Tcbuild\temp.win-amd64-3.9\Release\_openssl.c /Fobuild\temp.win-amd64-3.9\Release\build\temp.win-amd64-3.9\Release\_openssl.obj
_openssl.c
build\temp.win-amd64-3.9\Release\_openssl.c(575): fatal error C1083: Cannot open include file: 'openssl/opensslv.h': No such file or directory
error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio\\2019\\BuildTools\\VC\\Tools\\MSVC\\14.27.29110\\bin\\HostX86\\x64\\cl.exe' failed with exit code 2
ERROR: Failed building wheel for cryptography
Failed to build cryptography
ERROR: Could not build wheels for cryptography which use PEP 517 and cannot be installed directly
Now I’ve attempted to do my due diligence before posting here. And attempted to follow the instructions laid out on Cryptography’s website
They say to just do:
py -m pip install cryptography
Which I did, and got the following in response:
C:\Users\BRODI>py -m pip install cryptography
Requirement already satisfied: cryptography in c:\users\brodi\appdata\local\programs\python\python39\lib\site-packages (3.1.1)
Requirement already satisfied: cffi!=1.11.3,>=1.8 in c:\users\brodi\appdata\local\programs\python\python39\lib\site-packages (from cryptography) (1.14.3)
Requirement already satisfied: six>=1.4.1 in c:\users\brodi\appdata\local\programs\python\python39\lib\site-packages (from cryptography) (1.15.0)
Requirement already satisfied: pycparser in c:\users\brodi\appdata\local\programs\python\python39\lib\site-packages (from cffi!=1.11.3,>=1.8->cryptography) (2.20)
I attempted to run Home Assistant and apparently it wasn’t installed. So I ran the installer again and wound up getting the same error.
Finally I went to plan B. I installed the latest OpenSSL binary distribution from Softpedia. Win64OpenSSL-1_1_1h.exe, and attempted to use OpenSSL by creating the environment variables similar to the ones on Cryptography’s Website.
Example:
C:\> \path\to\vcvarsall.bat x86_amd64
C:\> set LIB=C:\OpenSSL-win64\lib;%LIB%
C:\> set INCLUDE=C:\OpenSSL-win64\include;%INCLUDE%
C:\> pip install cryptography
Mine:
Variable Name: HomeAssistant 1
Varriable Value:C:\Program Files (x86)\Microsoft Visual Studio\2019\BuildTools\VC\Auxiliary\Build\vcvarsall.bat x86_amd64
Variable Name: HomeAssistant 2
Variable Value:C:\> set LIB=C:\Program Files\OpenSSL-Win64\lib;%LIB%
Variable Name: HomeAssistant 3
Variable Value:C:\> set INCLUDE=C:\Program Files\OpenSSL-Win64\include;%INCLUDE%
Variable Name: HomeAssistant 4
Variable Value:C:\> pip install cryptography
I restarted my computer and tried to install Home Assistant one last time and again the same error popped up.
Can someone tell me what the heck I’m doing wrong?! I know I can run it as a Virtual Machine but I would rather run it locally. But if that’s what I have to do I guess I’ll do it…
Thanks in advanced for the help,
~BJ
Legion Y740-17IRHg
Windows 10 64bit
Intel(R) Core™ i7-9750H CPU @ 2.60GHz
Ram 16.0 GB
