I just installed Python 3.6 a on Win 10 Pro machine
Then I typed the following on the console:
$ pip3 install homeassistant
$ hass --open-ui
But I dont see anything else appear except a localhost on browser with the modules of python etc
I watched the Win 10 video but the speaker went straight into cmd and assumed homeautomation was installed
Install the 32 bit version rather than the 64 bit version; I forget what it is but one of the modules doesn’t work right under the 64 bit version. Somethng went wrong in your install somewhere as HA should always respond on port 8123.
You may want to read up on doing it as a Docker install - back when I was running this on Windows, I found out about it after and wished I had done it that way.
No problem buddy; that’s what projects like this are all about. Someone helped me, I learned. I’ll help you so you learn and then you can share that knowledge with another new user. You’ll find this a pretty friendly community and no one will fault you for not knowing something.
I just followed what you did and it seemed it successfully installed HA on my C:/users/homeautomation subdirectory .
However, I receive a message that it is “unable to find vcvarsall.bat " and that " You are using pip version 8.1.1 , know however version 8.1.2 is available …” I tried upgrading but it did not work
Also trying to call HA did not work ie using " $ pip3 install homeassistant
$ hass --open-ui " raised a syntax error
You shouldn’t have to install to any directory - I was never asked for a directory during install. All I did was install Python, run the command:
py -m pip install homeassistant
waited for the installation to complete and made sure there weren’t any errors. When it returned to the prompt, I typed in:
hass --open-ui
and that was it. Watched it start up in the command window for a bit and then minimized the window and opened up a browser and pointed to http://192.168.1.10:8123 (192.168.1.10 being my windows PC’s IP address). That was really all I did. No extra commands or installing anything. I’m not sure where you are going wrong if you watched that video as it was the same one I watched.
Are you seeing HA start up when you type the command? If not, then your install didn’t complete correctly
Are you keeping the window open or are you closing it? It needs to stay open; if you close the window, you stop HA.
and install the Visual C++ Compiler for Python from MS. Then rerun the installer. You won’t have to delete anything as anything the installer finds installed already should list as requirement satisfied.
See if that helps. And you should only have to use the command line from windows command “hass --open-ui” to start up HA, not go into Python at all. I would do this in an ADMINISTRATOR command window by the way, not just as a regular user. RIght click on your start button for the proper link. Also be aware that once you start up HA in this window, it has to stay open! If you close it, HA will close as well.
I’m starting to run out of ide4as; did you open an administrator command prompt or just a regular one?
It looks like the first time, it saw the hass command, but there was a space between the “–” and the open-ui, so I don’t understand why it didn’t see it the second time when you corrected it. Check and see if you have your path set up like this:
I just managed to do a “successful” Windows install this evening. It ran successfully in that it managed to boot up a browser window for the UI. I think there could be some net discovery issues in that it seems to not find anything (no hues, wemos, media players). I managed to get this far this time (I’ve tried a few times to get a windows install going) by uninstalling my python and reinstalling the 64bit ver.
I think some windows specific troubleshooting videos are in order.
