Wink Component - Fan only showing as binary sensor
I just added a fan, and it is only appearing as a binary sensor and not an actual fan. Anyone else having this issue?
The fan will make a “gang” binary sensor but you should get a fan entity as well. Did you check in the dev tools for the entity?
I did - and it did not create any new “fan.” entities…
Hmm, does the device show up in wink@home https://winkathome.net/Login.aspx?redirect=default.aspx
Is it functional in the official Wink app? Any errors in your logs?
Yes, it is completely functional in the wink app and does show up in Winkathome as a fan and the closest error I could see is:
[homeassistant.components.alarm_control_panel] Setup of platform wink is taking over 10 seconds.
Which is interesting as that is not a component I use…
:frowning: I tried removing it and re-adding it, and still just the binary sensor. I checked to see if was being added as a switch by some chance and nope…
This is odd. What kind of fan is it? Can you share access to your device with me via the wink app? This will allow me to see if it shows up in my HA.
Email is wjs . scanlon @ gmail . com
It’s a Home Decorators. I actually just finished moving this to Smartthings for now, as I needed it working. I’ll try and move it back to Wink later this week.
Okay, yeah I have that same one not sure why it isn’t showing up for you.
I will try and convert it back to Wink tomorrow - at which point, I won’t need the light/fan for a few days, so you can mess around at your leisure.
Cool, just let me know.
Done! Let me know when you’re done
