I’m trying to reconfigure my wink hub in home assistant, but I can’t log in to https://developer.wink.com/login I keep getting an error “Authentication Failed!” Is anyone else seeing this? I have had a valid developer account for years. I’ve tried Safari and Chrome, no luck with either.
This does not appear to be a Home Assistant configuration issue.
I was seeing the same things. There should be no reason to have to create a new dev account as long as you still have the client id and client secret and you are using the same callback URL/IP.
I’ve had the same issue for the past week. seems to be another one of the constant wink issues over the past couple of months. i have been able to get a client id and secret in only then to get 500 errors on from their servers so haven’t given up on getting wink into HA for the time being
