Wink FAN Issues
Running 0.79, When turning ON the Wink FAN (fan.name) on HA, It turns On, Set to Lowest speed,
And then on HA it turns itself Off (while fan continue to work in reality), There is no way to turn it Off
from HA, only from Wink App or the Remote.
Any Ideas,
I just came back to using HA after a long time it was Off, And I remember it used to work correctly.
Thanks,
Ebzed.
I am not seeing this issue with my fan. Can you try rebooting everything? Wink hub, HA, and the fan controller?
When you turn in the fan what speed do you have it set at initially before setting it to lowest?
Nothing beats a good reboot to everything! (Its working perfect now)
To your question, when turning the Fan it goes to lowest.
