Wink Hassio fan control?
I setup Hassio on raspi3b+ running .99I believe. I setup wink integration and can see all my devices except for fan speed control. I can see the fan light control but not the fan speed control. The HA page shows it can control the Hampton bay Wink remote so any ideas why I can’t see it?
You don’t see the fan listed in your developer states page?
i believe the only fan option i do see is for the light control. i’m not at home now but can check it later
Okay, check that, and also check your logs at startup to see if you are seeing any crashes.
I see fan.living_room_fan but on the overview screen the only fan option i see is for the light
Im sorry…i just tried the switch in the screenshot Nd it does actually turn the fan on but no speed control
If you click on the fan not the switch you should get the details page which has fan speed control
Ah i see it now…does this work with lovelace dashboard too?
Yeah, it should.
