I am new to Home Assistant and I am having trouble getting my Wink Hub 2 configured in the yaml. Here is my configuration. I put in all my information for the wink API but I get this error:
17-01-21 02:11:56 homeassistant.bootstrap: Invalid config for [homeassistant]: [wink] is an invalid option for [homeassistant]. Check: homeassistant->wink. (See /home/homeassistant/.homeassistant/configuration.yaml, line 2). Sorry if this has been asked before. But once i restart with this configuration Home Assistant does not start/
And here is the configuration.yaml
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 40.3514
longitude: -79.2575
Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 577
metric for Metric, imperial for Imperial
unit_system: imperial
Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/New_York
wink:
email:
password:
client_id:
client_secret:
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
http:
Uncomment this to add a password (recommended!)
api_password: PASSWORD
Uncomment this if you are using SSL or running in Docker etc
base_url: example.duckdns.org:8123
# Checks for available updates
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# Track the sun
sun:
# Weather Prediction
platform: yr
#Text to speech
tts:
platform: google
mqtt:
broker: 127.0.0.1
port: 1883
client_id: home-assistant-1
username: pi
password: raspberry
