Since my update to 0.72 my automation to turn off my fans after I leave is no longer working. The issue seems to be with my Quirky PPVG-WH01 Pivot Power Genius which is connected to my Wink 2 hub and the log shows an the following errors:
2018-06-24 11:11:20 INFO (MainThread) [homeassistant.components.automation] Executing No one home -> fans off
2018-06-24 11:11:21 ERROR (SubscribeMessageWorker) [homeassistant.components.wink] Error in pubnub JSON for Office Fan polling API for current state
2018-06-24 11:11:21 ERROR (SubscribeMessageWorker) [homeassistant.components.wink] Error in pubnub JSON for Outlet #2 polling API for current state
The pivot power genius isn’t connected to a hub it connects directly to Winks API via WiFi (no hub required) the error you are seeing are normal it’s a result of the pivot power genius being a legacy Wink device.
So, if you are having an issue with an automation I suspect the automation isn’t working correctly.
