Ever since I switched my Lutron Caseta dimmers over to my Wink Hub v1 last week Home Assistant seems to think they all control color changing bulbs. Is there any way to tell Home Assistant the type of lights are simple dimmable lights, instead of color changing? I’d take a way to hide them on a case by case basis (using CustomUI perhaps?).
This shouldn’t be happening, it is doing the same thing on all bulb I have connected. Something in HA must have changed on how they detect color. I am the Wink Dev on HA I’ll try to take a look in the next couple weeks and get a fix in for it.
Thank you @w1ll1am23. I switched those devices over when the Castea servers stopped working. I used it as an excuse to rid myself of at least one of my handful of hubs, and gave it to my sister with a switch so I’m committed now.
Anyway, this happened on both HASS.IO on my RaspberryPi and on my new Ubuntu Laptop Server, with HASS installed with Docker. It has persisted for several releases of HASS/HASS.IO (0.67.1, 0.68.0b0, 0.68.0b1, & now 0.68.0).
Let me know if there is anything I can do to help you troubleshoot this. I am a former website developer, and I’m a good tinkerer. To get you started here is a link to my light config package, in case my settings could shed any light on the issue.
https://github.com/brianhanifin/Home-AssistantConfig/blob/master/packages/lights.yaml
My wink.yaml package is straightforward:
wink:
#local_control: true
