Wink with ihome plug
The state of the plug is not working. I can turn on the plug but in the GUI it still shows that it is off when it is really on so I cant turn it off.
Has anyone seen this and have a fix?
Same issue here, but flipped. When I launch HA it shows all my plugs as on. I can turn them off, which moves the slider to the off position for 2 seconds, but then it goes right back on. Functionally I can only turn the ihome plugs off, not on. Hope there’s a fix.
I’ve casually been noticing the same behavior too. I’ll try to get some details later.
Also, there’s been a very active wink thread, so maybe this is pertaining to changes happening there too.
https://community.home-assistant.io/t/ha-stops-reporting-wink-state-changes/5884/160
Having this same issue too, new install
Same here, been this way for a while, tried re-installing the plugin but same thing happens, turn on switch, device turns on but switch goes back to off in HA.
