WiOn Woods Products
So i bought this product from Amazon before i learned about HA. Anyone have any idea how to add a component into HA?
http://tinyurl.com/jfxdefr
However I cannot find the actual product page, I dont think one exists.
So far… the device is reliable and works well outside. We will see if it holds up during the holidays.
I was tempted to get one of those too but checked for HA support first. Have you tried sniffing the traffic to it to see how it’s controlled? Does the device/app work if you’re on your home network but the network isn’t connected to the internet (device doesn’t need cloud relay)?
Haven’t had time to run a sniffer yet and i also haven’t tested without my internet down.
Any luck sniffing this WiOn product?
My apologies for bumping an older thread but all these WiOn products are just a rebrand of the Ecoplug product line from Kab Industries . They are based upon the esp8266 (ex version). These can be reflashed to work securely via MQTT with no cloud exposure, etc. I just use a homie-sonoff sketch and reassign pin numbers. I have the RC-028W and CT-065W in my HA system.
i have converted 2 of these so far into HA esp widgets. you have to solder some wires and get a serial connection working. connect 3.3v
rx
gnd
tx
io0
substitutions:
  friendly_name: wion1
  device_name: wion1
esphome:
  friendly_name: ${friendly_name}
  name_add_mac_suffix: false
  project:
    version: dev
esp8266:
  board: esp01_1m
# Enable logging
logger:
preferences:
  flash_write_interval: 1440min
time:
  - platform: homeassistant
# Enable Home Assistant API
api:
ota:
  - platform: esphome
improv_serial:
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
web_server:
wifi:
  ssid: flower
  password: flower88
  manual_ip:
    # Set this to the IP of the ESP
    static_ip: 192.168.1.19
    # Set this to the IP address of the router. Often ends with .1
    gateway: 192.168.1.254
    # The subnet of the network. 255.255.255.0 works for most home networks.
    subnet: 255.255.255.0
    dns1: 192.168.1.64
    dns2: 8.8.8.8
  ap:
    ssid: "Wion1 Fallback Hotspot"
    password: "wionsucks"
captive_portal:
network:
    enable_ipv6: true
    min_ipv6_addr_count: 2
mdns:
  disabled: false
switch:
  - platform: restart
    name: "xxx reboot wion 1!"
  - platform: gpio
    pin: GPIO15
    #inverted: True
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      mode:
        input: true
      inverted: true
    name: "wion 1 button"
    on_click:
      min_length: 30ms
      max_length: 500ms
      then:
        - switch.toggle: wion1
text_sensor:
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_2:
        name: ESP IP Address 2
    ssid:
      name: ESP Connected SSID
    bssid:
      name: ESP Connected BSSID
    mac_address:
      name: ESP Mac Wifi Address
    dns_address:
      name: ESP DNS Address
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    name: "WiFi Signal dB"
    update_interval: 60s
    entity_category: "diagnostic"
  - platform: copy # Reports the WiFi signal strength in %
    source_id: wifi_signal_db
    name: "WiFi Signal Percent"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "Signal %"
    device_class: ""
