A few days ago I installed hass.io (0.54) on my RPI B+, on a 32G sd card. I put in some HUE lights my doorbell and the Honeywell climate control. And did setup ssh access. This all worked.
Yesterday I noticed some strange entries in the log file, that there was not enough space in the database or something like that. Today I started looking in to this. First I did a df to see home much disk space there was. Only 5% used so more than enough free room on the SD card. Next I changed dir to /config and tried looked at the log file with tail homeassistant.log
And some a python error nothing to do with the sql error and not enough disk space.
Next thing, I get distracted and come back a few minutes later. I type in ls -al
in the shell and I get nothing, or actually total 0
as a response. Nothing there anymore! How is this possible?
What process can wipe all my files?
This never happened to me before. I have more than 20 years experience with linux/unix and have no clue.
in the mean time the complete file system has been wiped. All directories in / are gone. Even most commands are none functional anymore. ps is not working, top is not working.
Only thing that is still working is df
core-ssh:~# df -h
Filesystem Size Used Available Use% Mounted on
none 27.7G 1.3G 24.9G 5% /
tmpfs 240.7M 4.0K 240.7M 0% /dev
tmpfs 240.7M 0 240.7M 0% /sys/fs/cgroup
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /data
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /config
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /ssl
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /addons
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /backup
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /share
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /etc/resolv.conf
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /etc/hostname
/dev/mmcblk0p6 27.7G 1.3G 24.9G 5% /etc/hosts
shm 64.0M 0 64.0M 0% /dev/shm
tmpfs 240.7M 4.0K 240.7M 0% /proc/latency_stats
tmpfs 240.7M 4.0K 240.7M 0% /proc/timer_list
tmpfs 240.7M 4.0K 240.7M 0% /proc/timer_stats
tmpfs 240.7M 4.0K 240.7M 0% /proc/sched_debug
tmpfs 240.7M 0 240.7M 0% /sys/firmware
So looks like there is still something on the card, only nothing I can see or access.
really strange. Will need to powerdown the system and mount the sd card on my linux desktop to check if I can find any clues what is going on. Any help is appreciated.
