Wire for sensors (which and length?)
I’m doing all the electric installation at home and I want let ready the cabling for use some sensors. For example, i ordered all windows with contact sensors embedded in the frames. I also want to install some motion sensors. But I have several questions:
  • should I run all the cables to the technical room (center of the house) or distribute the controllers around the house.
  • The longer distance from the technical room till the sensor will be max 12 or 15 meters
  • I’m installing anyway UTP cables all around the house. Should I use it for the sensors or is it a bad idea?
    Thank you
