Wired and Wireless aqara wall switch. The same functions using zigbee2mqtt?
Hi guys,
I’m planning to buy smart switch http://www.zigbee2mqtt.io/devices/QBKG03LM) this is wired zigbee aqara wall switch with zero line.
Mostly I want it because of its possibility of generating 7 triggers ( single click, double click , long press, both keys click etc. ) theoretically I should be able to program actions like:
  • long press left button to turn off all lights in the house.
  • double press the right button to turn on kitchen light
  • press both buttons to turn on TV etc.
    Is it possible to do so?
I don’t have xiaomi gate, I use zigbee2mqtt.
On Koenkk supported devices http://www.zigbee2mqtt.io/information/supported_devices.html it clearly says that wireless switch has those options, but wired switch seemed to not have this possibilities.
So here is a question for someone who uses wired aqara smart switch zigbee version with zigbee2mqtt. Is it posiible to triger with it more action than just turn on/off light that its connected to? Are other actions available? And if so, which one?
Thanks in advance ! :slight_smile:
I have WXKG02LM and its working fine using Zigbee2mqtt USB Dongle CC2531
Great Bartosz !
Are you from Poland maybe? :slight_smile: Thanks for feedback. Can you please tell me if you can set up all extra triggers like long press, or double click to start different actions ? Or just On/Off the connected light?
I test in the evening all this triggers
Yes from poland.
To będę bardzo wdzięczny za informacje :slight_smile: bardzo zależy mi na tych dodatkowych opcjach, żeby móc kombinować jak pisałem powyżej: np: długie przytrzymanie lewego przycisku gasi światła w całym domu, a kliknięcie dwa razy włącza tv :smiley:
I will be very gratefull for information :slight_smile: those triggers are very important to me to start more comlicated routines with different triggers.
Hi all!
I hope you all are doing well :slight_smile:
@Yonguelle, did you find any solution to listen the events of the Wired aqara wall switch?
  • click left/ right buttom
  • double click left/ right buttom
  • long click left/ right buttom
  • press both buttoms
I am currently stuck in the same point and I would really apreciate any tip.
Thank you all for your time and help,
Best regards,
Enrique.
@euqiuq Yes I did, I ordered it and I can tell for sure :slight_smile:
Wired model has only standard actions on/off the light. There is no double click or long click or any other special function. Just turn the light on/off
Thank you so much for your reply :-).
I have bought the USB Dongle CC2531, I already flashed it and the switch is working fine with it, but I do not know how to confirgure the swicht as decouple mode.
@homeassistant.mi, do you know how to do it? I woluld really apreciate any help :slight_smile:
Thank you so much,
Enrique.
Hi all,
once the switch is configured as decoupled mode, you can only listen to the standar acctions (on/ off) as Yonguelle said before.
In my case, I have programed the lights outside my home, so I can use one of the buttoms in order to do something different, but only with the one click action.
Best regards.
Hello!
You may be right.
But when I use Acara Gateway and my switch in decoupled mode I can use both click function.
Why can’t I use this in zigbee2mqtt?
