Wireguard client configuration
Hello,I have to use HA remotely behind a router with a 4G provider in CG-NAT.
For the moment I parameter HA which is install on a raspeberry pi with debian 11 at my house before putting it into operation.
The goal is to have HA in a distant house and connect, control and view from my home on my pc so I install duckdns and wireguard add-on.
The configuration of duckdns is ok.
I just installed Wireguard on HA but I do not want to use my android but my pc with debian 11.
how to configure my pc and HA so that it connects via wireguard please?
thank you cordially
If you are attempting to use Wireguard in client mode on HassOS, this addon works great.
Had the same problem with my installation and the addon in repository. Yes, this addon works perfectly when you want to integrate HA in your preexistant wireguard scenery, tested with HAOS
  • Core 2024.5.3
  • Supervisor 2024.05.1
  • Operating System 12.3
    WG server running on edge OS 2.0.9
Hello, I have the same problem. I tried using the Wireguard Client addon. However, I’m having trouble exposing the HA interface through it. I understand is running inside a container, but I thought this was the intended use case.
The add-on runs in a docker container with elevated privileges, it can create a new wg interface on the host.
I use it with HA Supervised and I did not do anything extra apart from the add-on setup and I can access HA on the new interface via the tunnel.
Did you check routing and firewall on WG server and do you have proper AllowedIPs on both sides of the tunnel?
