I’m trying hard to get an esphome device connected via the new wireguard component. Like the title says, there is handshake and that’s it, not even ping response from expected esphome address while “connected”. My phone connects just fine.
I threw everything at the wall: different subnets (same as local or different) , different masks and peer_allowed_ips, static ip.
This is my Wireguard addon config:
server:
host: lwp***m841.duckdns.org
addresses:
- 192.168.95.1
dns:
- 192.168.0.1
- 1.1.1.1
peers:
- name: hallowolrdah
addresses:
- 192.168.95.2 #phone
- 192.168.95.3 #esphome device?
allowed_ips: []
client_allowed_ips:
- 192.168.0.0/24
This is the wireguard esphome config I’m trying to setup:
mdns:
time:
- platform: sntp
web_server:
port: 80
local: True
ota: true
wifi:
#use_address: 192.168.95.3
networks:
- ssid: Hotspot
password: testing123
manual_ip:
static_ip: 192.168.162.137
gateway: 192.168.162.4
subnet: 255.255.255.0
dns1: 192.168.162.4
wireguard:
private_key: redacted=
peer_endpoint: lwp***m841.duckdns.org
peer_public_key: redacted=
netmask: 255.255.255.0
peer_port: 51820
peer_allowed_ips:
- 192.168.0.0/24
#- 0.0.0.0/0
peer_persistent_keepalive: 25s
ESP Serial Log:
[I][wifi:560]: WiFi Connected!
[C][wifi:382]: Local MAC: [redacted]
[C][wifi:383]: SSID: [redacted]
[C][wifi:384]: IP Address: 192.168.162.137
[C][wifi:386]: BSSID: [redacted]
[C][wifi:387]: Hostname: 'esp32s3-1'
[C][wifi:389]: Signal strength: -42 dB ▂▄▆█
[C][wifi:393]: Channel: 6
[C][wifi:394]: Subnet: 255.255.255.0
[C][wifi:395]: Gateway: 192.168.162.4
[C][wifi:396]: DNS1: 192.168.162.4
[C][wifi:397]: DNS2: 0.0.0.0
[D][wifi:569]: Disabling AP...
[C][web_server:116]: Setting up web server...
[C][sntp:028]: Setting up SNTP...
[D][wireguard:037]: initializing WireGuard...
[I][wireguard:053]: WireGuard initialized
[C][ota:097]: Over-The-Air Updates:
[C][ota:098]: Address: 192.168.95.3:3232
[C][ota:101]: Using Password.
[W][ota:107]: Last Boot was an unhandled reset, will proceed to safe mode in 8 restarts
[C][api:025]: Setting up Home Assistant API server...
[I][app:062]: setup() finished successfully!
[D][wireguard:099]: WireGuard remote peer is offline (latest handshake timestamp not available)
[D][wireguard:203]: WireGuard is waiting for system time to be synchronized
[I][app:102]: ESPHome version 2023.9.3 compiled on Oct 17 2023, 19:31:06
[C][wifi:546]: WiFi:
[C][wifi:389]: Signal strength: -46 dB ▂▄▆█
[C][logger:357]: Logger:
[C][logger:358]: Level: DEBUG
[C][logger:359]: Log Baud Rate: 115200
[C][logger:361]: Hardware UART: UART0
[C][captive_portal:088]: Captive Portal:
[C][web_server:161]: Web Server:
[C][web_server:162]: Address: 192.168.95.3:80
[C][sntp:053]: SNTP Time:
[C][sntp:054]: Server 1: '0.pool.ntp.org'
[C][sntp:055]: Server 2: '1.pool.ntp.org'
[C][sntp:056]: Server 3: '2.pool.ntp.org'
[C][sntp:057]: Timezone: 'EET-2EEST,M3.5.0/3,M10.5.0/4'
[C][wireguard:126]: WireGuard:
[C][wireguard:127]: Address: 192.168.95.3
[C][wireguard:128]: Netmask: 255.255.255.0
[C][wireguard:129]: Private Key: [redacted]
[C][wireguard:130]: Peer Endpoint: [redacted]
[C][wireguard:131]: Peer Port: [redacted]
[C][wireguard:132]: Peer Public Key: [redacted]
[C][wireguard:134]: Peer Pre-shared Key: [redacted]
[C][wireguard:135]: Peer Allowed IPs:
[C][wireguard:137]: - 192.168.0.0/255.255.255.0
[C][wireguard:140]: Peer Persistent Keepalive: 25s
[C][wireguard:142]: Reboot Timeout: 900s
[C][wireguard:144]: Require Connection to Proceed: NO
[C][wireguard:145]: Update Interval: 10.0s
[C][mdns:115]: mDNS:
[C][mdns:116]: Hostname: esp32s3-1
[C][api:138]: API Server:
[C][api:139]: Address: 192.168.95.3:6053
[C][api:141]: Using noise encryption: YES
[D][sntp:078]: Synchronized time: 2023-10-17 19:52:20
[D][wireguard:212]: starting WireGuard connection...
[D][esp-idf:000]: E (28051) esp_wireguard: getaddrinfo: unable to resolve `l[redacted].duckdns.org`
[D][esp-idf:000]: E (28061) esp_wireguard: esp_wireguard_peer_init: ESP_FAIL
[W][wireguard:228]: cannot start WireGuard connection, error code -1
[W][component:204]: Component sntp.time took a long time for an operation (7.04 s).
[W][component:205]: Components should block for at most 20-30ms.
[I][wireguard:226]: WireGuard connection started
[D][wireguard:232]: configuring WireGuard allowed IPs list...
[D][wireguard:240]: allowed IPs list configured correctly
[W][component:204]: Component wireguard took a long time for an operation (2.19 s).
[I][wireguard:089]: WireGuard remote peer is online (latest handshake 2023-10-17 19:52:29 EEST)
Wireguard addon log:
[20:23:10] INFO: Requesting current status from WireGuard...
interface: wg0
public key: (hidden)
private key: (hidden)
listening port: 51820
peer: (hidden)
endpoint: redacted:58947
allowed ips: 192.168.95.2/32, 192.168.95.3/32
latest handshake: 48 seconds ago
transfer: 2.98 KiB received, 7.79 KiB sent
persistent keepalive: every 25 seconds
I am not using the WG in HA, but I run it in my router instead. The WG in router works just fine for my laptop, and phone, but the ESPHome keep saying “WireGuard remote peer is offline”
